08-20-2012 02:35 PM - edited 03-16-2019 12:47 PM
Tested this gateway before we deployed it in another town and have run into a problem One problem was inbound dialing which I corrected by battery-reversal on the FXO ports. I still have problem outbound though. I see the port go off-hook for a second and then back on-hook. Get a fast busy on the call. It appears to be hitting the right dial-peer in the ccapi debug but when I do a debug dialpeer I don't see anything. Like I said, it worked perfectly at the corporate office while testing. Not sure where else to look. Any ideas???
Here is the debug ccapi. Dialed number is 9 9857916891
BN-USHUM01-RTR01#
Aug 20 21:29:23.855: //-1/801D293F0D00/CCAPI/cc_api_display_ie_subfields:
cc_api_call_setup_ind_common:
cisco-username=Houma Test
----- ccCallInfo IE subfields -----
cisco-ani=9858763175
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=99857916981
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=-1
cisco-rdnplan=-1
cisco-rdnpi=-1
cisco-rdnsi=-1
cisco-redirectreason=-1 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
Aug 20 21:29:23.859: //-1/801D293F0D00/CCAPI/cc_api_call_setup_ind_common:
Interface=0x2AEED678, Call Info(
Calling Number=9858763175,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=99857916981(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
Incoming Dial-peer=0, Progress Indication=NULL(0), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=47
Aug 20 21:29:23.859: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Aug 20 21:29:23.859: :cc_get_feature_vsa malloc success
Aug 20 21:29:23.859: cc_get_feature_vsa count is 1
Aug 20 21:29:23.859: :FEATURE_VSA attributes are: feature_name:0,feature_time:1106321696,feature_id:47
Aug 20 21:29:23.859: //47/801D293F0D00/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=9858763175(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=99857916981(TON=Unknown, NPI=Unknown))
Aug 20 21:29:23.859: //47/801D293F0D00/CCAPI/cc_process_call_setup_ind:
Event=0x2B0CB348
Aug 20 21:29:23.859: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number 99857916981
Aug 20 21:29:23.859: //47/801D293F0D00/CCAPI/ccCallSetContext:
Context=0x420E248C
>>>>CCAPI handed cid 47 with tag 0 to app "_ManagedAppProcess_Default"
Aug 20 21:29:23.859: //47/801D293F0D00/CCAPI/ccCallProceeding:
Aug 20 21:29:23.859: //47/801D293F0D00/CCAPI/ccCallSetupRequest:
Destination=, Calling IE Present=TRUE, Mode=0,
Outgoing Dial-peer=6, Params=0x420E399C, Progress Indication=NULL(0)
Aug 20 21:29:23.859: //47/801D293F0D00/CCAPI/ccCheckClipClir:
In: Calling Number=9858763175(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Out: Calling Number=9858763175(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Destination Pattern=9[2-9]........., Called Number=99857916981, Digit Strip=TRUE
Redirect Number=, Display Info=
Account Number=Houma Test, Final Destination Flag=TRUE,
Guid=801D293F-70AC-2103-0D00-A0020A200710, Outgoing Dial-peer=6
Aug 20 21:29:23.859: //47/801D293F0D00/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=99857916981
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=-1
cisco-rdnplan=-1
cisco-rdnpi=-1
cisco-rdnsi=-1
Aug 20 21:29:23.863: //47/801D293F0D00/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0xC1A17924, Interface Type=6, Destination=, Mode=0x0,
Call Params(Calling Number=9858763175,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=99857916981(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=6, Call Count On=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Aug 20 21:29:23.863: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Aug 20 21:29:23.863: :cc_get_feature_vsa malloc success
Aug 20 21:29:23.863: cc_get_feature_vsa count is 2
Aug 20 21:29:23.863: :FEATURE_VSA attributes are: feature_name:0,feature_time:1106321472,feature_id:48
Aug 20 21:29:23.863: //48/801D293F0D00/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
Aug 20 21:29:23.863: //48/801D293F0D00/CCAPI/ccCallSetContext:
Context=0x420E394C
Aug 20 21:29:23.863: //47/801D293F0D00/CCAPI/ccSaveDialpeerTag:
Aug 20 21:29:23.863: //48/801D293F0D00/CCAPI/cc_api_call_proceeding:
Interface=0xC1A17924, Progress Indication=NULL(0)
Aug 20 21:29:25.115: //48/801D293F0D00/CCAPI/cc_api_call_disconnected:
Cause Value=34, Interface=0xC1A17924, Call Id=48
Call Entry(Responsed=TRUE, Cause Value=34, Retry Count=0)
Aug 20 21:29:25.115: //47/801D293F0D00/CCAPI/ccCallReleaseResources:
release reserved xcoding resource.
Aug 20 21:29:25.115: //48/801D293F0D00/CCAPI/ccCallSetAAA_Accounting:
Accounting=0, Call Id=48
Aug 20 21:29:25.115: //48/801D293F0D00/CCAPI/ccCallDisconnect:
Cause Value=34, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=34)
Cause Value=34, Call Entry(Responsed=TRUE, Cause Value=34)
Aug 20 21:29:25.115: //48/801D293F0D00/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0xC1A17924, Tag=0x0, Call Id=48,
Call Entry(Disconnect Cause=34, Voice Class Cause Code=0, Retry Count=0)
Call Disconnect Event Sent
Aug 20 21:29:25.115: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Aug 20 21:29:25.115: :cc_free_feature_vsa freeing 41F12038
Aug 20 21:29:25.115: vsacount in free is 1
Aug 20 21:29:25.119: //47/801D293F0D00/CCAPI/ccCallDisconnect:
Cause Value=34, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Aug 20 21:29:25.119: //47/801D293F0D00/CCAPI/cc_api_get_transfer_info:
Transfer Number Is Null
Aug 20 21:29:25.119: //47/801D293F0D00/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x2AEED678, Tag=0x0, Call Id=47,
Aug 20 21:29:25.119: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Aug 20 21:29:25.119: :cc_free_feature_vsa freeing 41F12118
Aug 20 21:29:25.119: vsacount in free is 0
Config is attached
08-20-2012 02:36 PM
Take debug vpm signal.
08-20-2012 02:38 PM
Actually the debug dial peer is working. Here is the vpm debug.
BN-USHUM01-RTR01#
Aug 20 21:37:10.327: htsp_timer_stop3 htsp_setup_req
Aug 20 21:37:10.327: htsp_process_event: [0/0/0, FXOLS_ONHOOK, E_HTSP_SETUP_REQ]fxols_onhook_setup
Aug 20 21:37:10.327: [0/0/0] set signal state = 0xC timestamp = 0
Aug 20 21:37:10.327: htsp_timer - 1300 msec
Aug 20 21:37:10.579: htsp_process_event: [0/0/0, FXOLS_WAIT_DIAL_TONE, E_DSP_SIG_1100]fxols_power_denial_detected
Aug 20 21:37:10.579: htsp_timer2 - 1000 msec
Aug 20 21:37:10.579: htsp_timer_stop
Aug 20 21:37:11.579: htsp_process_event: [0/0/0, FXOLS_WAIT_DIAL_TONE, E_HTSP_EVENT_TIMER2]fxols_power_den_disc
Aug 20 21:37:11.579: htsp_timer_stop
Aug 20 21:37:11.579: htsp_timer_stop2
Aug 20 21:37:11.579: [0/0/0] set signal state = 0x4 timestamp = 0
Aug 20 21:37:11.579: htsp_process_event: [0/0/0, FXOLS_ONHOOK, E_HTSP_RELEASE_REQ]fxols_onhook_release
BN-USHUM01-RTR01#
08-20-2012 03:11 PM
There is some issue with the circuit, low or unrealiable loop current.
08-20-2012 04:46 PM
Battery reversal fixed inbound calling? Makes me start to think you might be hitting a ground start circuit but your debugs are showing it as loop start. Try switching the signaling and see if that helps. Make sure you do a shut no shut on the voice port for the change to take place.
