Outbound DID showing company pilot number
Hello Guys,
I am running CUCME on a cisco ISR 2801 router. I am having problems with outbound DID, when i place a call from my IP Phone to PSTN the company pilot number (4602000) displays. But when i place a call from GSM to the IP Phone on my desk (4602019) it goes directly to my desk. I have discussed with the telco and they said they have enable both incoming/outgoing DID. I also did a debug isdn q931 and it shows that everything is ok. find below the config and the debug output.
isdn switch-type primary-net5
voice translation-rule 1
rule 1 /4602000/ /2000/
rule 2 /4602010/ /2010/
rule 3 /4602011/ /2011/
rule 4 /4602012/ /2012/
rule 5 /4602013/ /2013/
rule 6 /4602014/ /2014/
rule 7 /4602015/ /2015/
rule 8 /4602016/ /2016/
rule 9 /4602017/ /2017/
rule 10 /4602018/ /2018/
rule 11 /4602019/ /2019/
rule 12 /4602020/ /2020/
rule 14 /4602022/ /2022/
rule 15 /4602023/ /2023/
rule 16 /4602024/ /2024/
voice translation-rule 2
rule 1 /^20\(..\)$/ /46020\1/
voice translation-profile expandcalling
translate calling 2
voice translation-profile pstn-incoming
translate called 1
dial-peer voice 1 pots
translation-profile incoming pstn-incoming
incoming called-number 460201.
direct-inward-dial
dial-peer voice 2 pots
incoming called-number 460202.
direct-inward-dial
dial-peer voice 3 pots
incoming called-number 460203.
direct-inward-dial
dial-peer voice 4 pots
translation-profile outgoing expandcalling
destination-pattern 9T
port 0/3/0:15
dial-peer voice 5 pots
incoming called-number 460200.
direct-inward-dial
DEBUG OUTPUT
FROM IP Phone TO GSM
Jul 25 08:24:20.321: ISDN Se0/3/0:15 Q931: Applying typeplan for sw-type 0x12 is
0x0 0x1, Calling num 4602019
Jul 25 08:24:20.321: ISDN Se0/3/0:15 Q931: Sending SETUP  callref = 0x0082 callI
D = 0x8003 switch = primary-net5 interface = User
Jul 25 08:24:20.321: ISDN Se0/3/0:15 Q931: TX -> SETUP pd = 8  callref = 0x0082
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98384
                Exclusive, Channel 4
        Progress Ind i = 0x8183 - Origination address is non-ISDN
        Calling Party Number i = 0x0180, '4602019'
                Plan:ISDN, Type:Unknown
        Called Party Number i = 0x81, '08030718911'
Jul 25 08:24:20.357: ISDN Se0/3/0:15 Q931: RX <- SETUP_ACK pd = 8  callref = 0x8
082
Jul 25 08:24:25.405: ISDN Se0/3/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x8
082
Jul 25 08:24:28.357: ISDN Se0/3/0:15 Q931: RX <- ALERTING pd = 8  callref = 0x80
82
        Progress Ind i = 0x8488 - In-band info or appropriate now available
Jul 25 08:24:35.825: ISDN Se0/3/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x
0082
        Cause i = 0x8090 - Normal call clearing
Jul 25 08:24:35.885: ISDN Se0/3/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x808
Jul 25 08:24:35.889: ISDN Se0/3/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref =
0x0082
FROM GSM To IP Phone
Jul 25 08:25:42.477: ISDN Se0/3/0:15 Q931: RX <- SETUP pd = 8  callref = 0x0083
        Sending Complete
                Standard = CCITT
        Calling Party Number i = 0x0083, '08030718911'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0xC1, '4602019'
                Plan:ISDN, Type:Subscriber(local)
Jul 25 08:25:42.481: ISDN Se0/3/0:15 Q931: Received SETUP  callref = 0x8083 call
ID = 0x000B switch = primary-net5 interface = User
Jul 25 08:25:42.517: ISDN Se0/3/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x8
083
Jul 25 08:25:42.517: ISDN Se0/3/0:15 Q931: TX -> ALERTING pd = 8  callref = 0x80
83
        Progress Ind i = 0x8188 - In-band info or appropriate now available
Jul 25 08:25:49.877: ISDN Se0/3/0:15 Q931: TX -> CONNECT pd = 8  callref = 0x808
Jul 25 08:25:49.905: ISDN Se0/3/0:15 Q931: RX <- CONNECT_ACK pd = 8  callref = 0
x0083
Jul 25 08:25:49.909: %ISDN-6-CONNECT: Interface Serial0/3/0:3 is now connected t
o 4602019 Enterprised Dept.
Jul 25 08:25:51.025: %ISDN-6-DISCONNECT: Interface Serial0/3/0:3  disconnected f
rom 08030718911 , call lasted 1 seconds
Jul 25 08:25:51.029: ISDN Se0/3/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x
8083
Jul 25 08:25:51.089: ISDN Se0/3/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x008
Jul 25 08:25:51.093: ISDN Se0/3/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref =
0x8083
Blue
Since debug Q931 shows your DID number , I would say your service provider is overwriting the calling number to your pilot number. Check with your service provider again and give them debug output prrof.
Ronak Patel
rate helpful posts
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
hello Ronak,
i guessed as much too,will contact the telcos and update on any outcome.
thanks
321
