Outbound Fax Issues
We're having issues with faxing outbound with a fax machine hooked directly to an FXS port.  After all digits are dialed we receive a fast busy.  Looking at debug voip dialpeer, I see where each individual digit is dialed and then when they are all dialed it successfully matches our outbound 9T dial-peer.  We are able to make inbound calls/faxes to this it's just not working outbound.  We also tried a phone hooked to this cable and were able to receive a call but not make a call.  Unfortunately I didn't save the debug voip dialpeer results.
Below is part of our configuration:
voice translation-rule 1
rule 1 /2300/ /6800/
rule 2 /2201/ /6801/
rule 3 /22/ /22/
rule 4 /23/ /23/
rule 5 /..../ /6750/
voice rtp send-recv
voice service pots
voice service voip
signaling forward unconditional
fax protocol pass-through g711ulaw
fax-relay ans-disable
h323
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice-port 0/0/0:23
translation-profile incoming LBWCC
voice-port 0/3/0<------------------------fax hooked to this port
voice-port 0/3/1
shutdown
sccp local GigabitEthernet0/0.50
sccp ccm 10.101.0.5 identifier 2 priority 2 version 7.0
sccp ccm 10.101.0.4 identifier 1 priority 1 version 7.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate ccm 2 priority 2
associate profile 1 register 10.101.255.254
dspfarm profile 1 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g722-64
maximum sessions 3
associate application SCCP
dial-peer voice 9 pots
description Outside Line
destination-pattern 9T
port 0/0/0:23
dial-peer voice 6800 pots
description FAX1
destination-pattern 6800
incoming called-number .
port 0/3/0
1 ACCEPTED SOLUTION
Outbound Fax Issues
I was going to suggest that you check with the end user to see exactly what number they were dialing.  I am glad you were able to resolve this issue.
Outbound Fax Issues
To anyone with this issue, I was not onsite dialing at the time and the person I was working with was dialing a 1 after the 9 for an outside line which the telco was rejecting.  Without the 1 the call completed successfully.
Outbound Fax Issues
257
