Outbound issue with BRI
jeroenhermans
Level 5
Level 5
We're having an issue with a new setup. The router is a 2811 and has 4 BRI interfaces. The telco is Swisscom from Switzerland. The four lines are configured as a group on the telco side.
Inbound calls are working, but when trying to call out, the call is dropped.
Doing a debug isdn q931 shows :
000574: Jun 24 11:58:32.521 PCTime: ISDN BR0/2/0 Q931: Applying typeplan for sw-type 0x1 is 0x0 0x0, Calling num 022365xxxx
000575: Jun 24 11:58:32.525 PCTime: ISDN BR0/2/0 Q931: Applying typeplan for sw-type 0x1 is 0x0 0x0, Called num 003247595xxxx
000576: Jun 24 11:58:32.525 PCTime: ISDN BR0/2/0 Q931: TX -> SETUP pd = 8 callref = 0x0D
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x89
Exclusive, B1
Calling Party Number i = 0x0081, '022365xxxx'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '003247595xxxx'
000577: Jun 24 11:58:32.609 PCTime: ISDN BR0/2/0 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x8D
Cause i = 0x82E404 - Invalid information element contents
When I compare this with an inbound call
000582: Jun 24 11:59:28.925 PCTime: ISDN BR0/3/0 Q931: RX <- SETUP pd = 8 callref = 0x01
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Channel ID i = 0x89
Exclusive, B1
Calling Party Number i = 0x0183, '003247595xxxx'
Plan:ISDN, Type:Unknown
Called Party Number i = 0x81, '71'
High Layer Compat i = 0x9181
000583: Jun 24 11:59:28.945 PCTime: ISDN BR0/3/0 Q931: TX -> CALL_PROC pd = 8 callref = 0x81
Channel ID i = 0x89
Exclusive, B1
000584: Jun 24 11:59:29.169 PCTime: ISDN BR0/3/0 Q931: TX -> ALERTING pd = 8 callref = 0x81
000585: Jun 24 11:59:32.093 PCTime: ISDN BR0/3/0 Q931: TX -> CONNECT pd = 8 callref = 0x81
Channel ID i = 0x89
Exclusive, B1
000586: Jun 24 11:59:32.213 PCTime: ISDN BR0/3/0 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x01
000587: Jun 24 11:59:32.217 PCTime: %ISDN-6-CONNECT: Interface BRI0/3/0:1 is now connected to 003247595xxxx N/A
000588: Jun 24 11:59:38.217 PCTime: %ISDN-6-CONNECT: Interface BRI0/3/0:1 is now connected to 003247595xxxx N/A
000589: Jun 24 11:59:48.929 PCTime: ISDN BR0/3/0 Q931: RX <- DISCONNECT pd = 8 callref = 0x01
Cause i = 0x8090 - Normal call clearing
Progress Ind i = 0x8288 - In-band info or appropriate now available
000590: Jun 24 11:59:48.929 PCTime: %ISDN-6-DISCONNECT: Interface BRI0/3/0:1 disconnected from 003247595xxxx , call lasted 16 seconds
000591: Jun 24 11:59:48.949 PCTime: ISDN BR0/3/0 Q931: TX -> RELEASE pd = 8 callref = 0x81
000592: Jun 24 11:59:49.013 PCTime: ISDN BR0/3/0 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x01
The only difference I can see is the bearer cap, for inbound it is 0x8090A3 which means Voice/Speech call (A-law) and for outbound it is 0x8090A2 which means Voice/Speech call (u-law))
How and where can I specify I want to use G711 Alaw for outbound calls?
Jeroen
paolo bevilacqua
Under voice-port, compand-type a-law.
6 Replies 6
paolo bevilacqua
Thanks for your reply. This solved my problem!
Rgds,
Jeroen
Thanks for the appreciation and good luck!
Paolo,
Could you please tell me the exact function of this command & how it helped resolve this issue?
Ashok.
North America uses a PCM companding algorithm called U law tat is the default. Rest of the world uses A law and must be configured accordingly.
Thanks a lot Paolo, have a nice day.
