Outbound issue with BRI
We're having an issue with a new setup. The router is a 2811 and has 4 BRI interfaces. The telco is Swisscom from Switzerland. The four lines are configured as a group on the telco side.
Inbound calls are working, but when trying to call out, the call is dropped.
Doing a debug isdn q931 shows :
000574: Jun 24 11:58:32.521 PCTime: ISDN BR0/2/0 Q931: Applying typeplan for sw-type 0x1 is 0x0 0x0, Calling num 022365xxxx
000575: Jun 24 11:58:32.525 PCTime: ISDN BR0/2/0 Q931: Applying typeplan for sw-type 0x1 is 0x0 0x0, Called num 003247595xxxx
000576: Jun 24 11:58:32.525 PCTime: ISDN BR0/2/0 Q931: TX -> SETUP pd = 8 callref = 0x0D
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x89
Exclusive, B1
Calling Party Number i = 0x0081, '022365xxxx'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '003247595xxxx'
000577: Jun 24 11:58:32.609 PCTime: ISDN BR0/2/0 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x8D
Cause i = 0x82E404 - Invalid information element contents
When I compare this with an inbound call
000582: Jun 24 11:59:28.925 PCTime: ISDN BR0/3/0 Q931: RX <- SETUP pd = 8 callref = 0x01
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Channel ID i = 0x89
Exclusive, B1
Calling Party Number i = 0x0183, '003247595xxxx'
Plan:ISDN, Type:Unknown
Called Party Number i = 0x81, '71'
High Layer Compat i = 0x9181
000583: Jun 24 11:59:28.945 PCTime: ISDN BR0/3/0 Q931: TX -> CALL_PROC pd = 8 callref = 0x81
Channel ID i = 0x89
Exclusive, B1
000584: Jun 24 11:59:29.169 PCTime: ISDN BR0/3/0 Q931: TX -> ALERTING pd = 8 callref = 0x81
000585: Jun 24 11:59:32.093 PCTime: ISDN BR0/3/0 Q931: TX -> CONNECT pd = 8 callref = 0x81
Channel ID i = 0x89
Exclusive, B1
000586: Jun 24 11:59:32.213 PCTime: ISDN BR0/3/0 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x01
000587: Jun 24 11:59:32.217 PCTime: %ISDN-6-CONNECT: Interface BRI0/3/0:1 is now connected to 003247595xxxx N/A
000588: Jun 24 11:59:38.217 PCTime: %ISDN-6-CONNECT: Interface BRI0/3/0:1 is now connected to 003247595xxxx N/A
000589: Jun 24 11:59:48.929 PCTime: ISDN BR0/3/0 Q931: RX <- DISCONNECT pd = 8 callref = 0x01
Cause i = 0x8090 - Normal call clearing
Progress Ind i = 0x8288 - In-band info or appropriate now available
000590: Jun 24 11:59:48.929 PCTime: %ISDN-6-DISCONNECT: Interface BRI0/3/0:1 disconnected from 003247595xxxx , call lasted 16 seconds
000591: Jun 24 11:59:48.949 PCTime: ISDN BR0/3/0 Q931: TX -> RELEASE pd = 8 callref = 0x81
000592: Jun 24 11:59:49.013 PCTime: ISDN BR0/3/0 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x01
The only difference I can see is the bearer cap, for inbound it is 0x8090A3 which means Voice/Speech call (A-law) and for outbound it is 0x8090A2 which means Voice/Speech call (u-law))
How and where can I specify I want to use G711 Alaw for outbound calls?
Jeroen
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: Outbound issue with BRI
Under voice-port, compand-type a-law.
Thanks for your reply. This solved my problem!
Rgds,
Jeroen
Thanks for the appreciation and good luck!
Paolo,
Could you please tell me the exact function of this command & how it helped resolve this issue?
Ashok.
North America uses a PCM companding algorithm called U law tat is the default. Rest of the world uses A law and must be configured accordingly.
Thanks a lot Paolo, have a nice day.
176
