Outbound number identification - CME 7.1
I have and issue that the outbound calling info is incorrect from the 2811 CME box. We currently have a PRI terminated into this box and would like to change the number being sent/displayed on outbound calls to external cell phones/devices. Any idea how I do this?
2 ACCEPTED SOLUTIONS
Re: Outbound number identification - CME 7.1
If you want to have the same number for all outgoing calls then you can add "isdn calling-number xxx-xxx-xxxx" to your serial interface as shown below.  If you want everyone's DID to go out as there own number then you will need to create translation's on your gateway to do acheive this.
interface Serial6/0:23
no ip address
no logging event link-status
isdn switch-type primary-ni
isdn incoming-voice voice
no cdp enable
HTH, Please rate if so.
Justin
If using translation rules to mask everyone to the same number:
voice translation-rule 1
rule 1 /.*/ /3305551212/
voice translation-profile CALLERID
translate calling 1
dial-peer voice 10 pots
translation-profile outgoing CALLERID
destination-pattern 81[2-9].........
port 1/0/0:23
forward-digits 11
no ip address
no cdp enable
Justin
translate calling 1
port 1/0/0:23
forward-digits 11
Thank you. This worked perfectly.
Hall of Fame Super Gold
How the current number is incorrect, and what number you want to display instead ?
Thank you. The above suggestions worked for me.
212
