Community Member
Outbound pots dial-peers
Trying to map outbound local and LD calls to their respective T1's based on dial-peers.
How do I make a specifice match for local calls to use certain ports regardless of dial-peer pref?
As it is now it matches all peers when I dial a local 10 digit number beginning 651XXX-XXXX but I want it to match pots dp 3 instead of going out pots dp 6. Any suggestions?
dial-peer voice 3 pots
description MNLX_Local_RG Primary
preference 3
destination-pattern [651,763,612,952].
progress_ind setup enable 3
progress_ind progress enable 8
progress_ind connect enable 8
incoming called-number .
direct-inward-dial
port 7/0:16:D
dial-peer voice 4 pots
description MNLX_Local_RG Secondary
preference 4
direct-inward-dial
port 7/0:15:D
dial-peer voice 5 pots
description MN Gen LD
preference 2
destination-pattern [2-9].
direct-inward-dial
port 7/0:13:D
dial-peer voice 6 pots
preference 1
direct-inward-dial
port 7/0:14:D
Dec 11 21:48:14.814: //-1/003F7FC53300/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
List of Matched Outgoing Dial-peer(s):
1: Dial-peer Tag=6
2: Dial-peer Tag=5
3: Dial-peer Tag=3
4: Dial-peer Tag=4
Dec 11 21:48:14.814: ISDN Se7/0:14:23 Q931: pak_private_number: Invalid type/plan 0x0 0x0 may be overriden; sw-type 2
Dec 11 21:48:14.814: ISDN Se7/0:14:23 Q931: Applying typeplan for sw-type 0x2 is 0x2 0x1, Calling num 8512
Dec 11 21:48:14.818: ISDN Se7/0:14:23 Q931: Applying typeplan for sw-type 0x2 is 0x2 0x1, Called num 6513238925
Dec 11 21:48:14.818: ISDN Se7/0:14:23 Q931: TX -> SETUP pd = 8 callref = 0x00BB
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98397
Exclusive, Channel 23
Net Specific Fac i = 0x00E1
Calling Party Number i = 0x2181, '8512'
Plan:ISDN, Type:National
Called Party Number i = 0xA1, '6513238925'
Dec 11 21:48:14.878: ISDN Se7/0:14:23 Q931: RX <- CALL_PROC pd = 8 callref = 0x80BB
Channel ID i = 0xE9808397
Exclusive, Interface 0, Channel 23
Dec 11 21:48:16.698: ISDN Se7/0:14:23 Q931: RX <- ALERTING pd = 8 callref = 0x80BB
Dec 11 21:48:17.346: ISDN Se7/0:14:23 Q931: TX -> DISCONNECT pd = 8 callref = 0x00BB
Cause i = 0x8090 - Normal call clearing
Dec 11 21:48:17.406: ISDN Se7/0:14:23 Q931: RX <- RELEASE pd = 8 callref = 0x80BB
Dec 11 21:48:17.410: ISDN Se7/0:14:23 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x00BB
3 pots up up [651,763,612,952]. 3 up 7/0:16:D
4 pots up up [651,763,612,952]. 4 up 7/0:15:D
5 pots up up [2-9]. 2 up 7/0:13:D
6 pots up up [2-9]. 1 up 7/0:14:D
1 REPLY
Silver
Re: Outbound pots dial-peers
Dial-peer preference is the best way to match dial-peer or try with exact destination-pattern match for ex destination-patern1001, destination-patern1002.
143
