Outbound Ringback Issues over SIP trunk using CUCM 8.6 and H323 Gateway
Im using a SIP provider (voip.ms) to a H323 gateway (2801) and from there go to my CUCM 8.6 server.  Inbound calls work fine, i get ringback and outbound calls connect and work fine, i just hear no ringback on my outbound calls via my SIP provider.
Attached are my debug ccsip messages, debug ccsip calls and debug ccapi inout as well as my running config
Here is also a link to another thread for other stuff ive tried:
http://www.techexams.net/forums/ccnp-voice/78494-outbound-ringback-issues.html
If anyone could solve this, you would be my hero!!!!
1 ACCEPTED SOLUTION
VIP Super Bronze
Yes. On cucm setup a sip trunk, the detsination address will be your cube gateway. Assign MRGL with ANN to the sip trunk.
2. On your gateway configure the ff:
voice servie voip
sip
  bind control source-interface "xxxx"-----xxxx= your inerface eg gig0/0 of fa0/0
  bind media source-interface "xxxx"
options-ping 60
early-offer forced.......................If you want to use early offer otherwise you can remove this
voice class codec 1---------------------------------to advertise different codecs, change preference as you want
codec preference 1 g729r8
codec preference 2 g711ulaw
codec preference 3 g711alaw
dial-peer voice 1 voip---------------------------------This will be your default dial-peer for incoming calls from cucm and sip provider
session portocol sipv2
incoming called-number .
voice-class codec 1
dtmf-relay rtp-nte
I believe you already have a dial-peer with sip protocl going to your ITSP.
Please rate useful posts
"For the love of God is broader than the measure of man's mind And the heart of the Eternal is most wonderfully kind"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
VIP Super Bronze
  Hi John,
By default, Cisco Unified Communications Manager  will signal the calling phone to play local ringback if SDP is not  received in the 180 or 183 response. If SDP is included in the 180 or  183 response, instead of playing ringback locally, Cisco Unified  Communications Manager will connect media, and the calling phone will  play whatever the called device is sending (such as ringback or busy  signal). If you do not receive ringback, the device to which you are  connecting may be including SDP in the 180 response, but it is not  sending any media before the 200OK response. In this case
The log you sent does not contain the debug ccsip messages, so I am unable to determine if you receive 183 with SDP. If your provider is sending 183 without SDP, then cucm should be teliing the phone to play ringback locally. However CUCM uses Annunciator to play ringback for sip trunks. So you need to ensure that you have ANNunciator in your MRG and assign this MRG to a MRGL and inturn assign the MRGL to your phones and cube gateway
If you are receiving 183 with SDP but still not getting ringback, then try you can use a feature called disable early media to force cucm to play ringback locally..(dont forget to enable Annunciator and assign to phones and cube gateway)
disable-early-media 180
To specify which call treatment, early media or local ringback, is provided for 180 responses with 180
responses with Session Description Protocol (SDP), use the disable-early-media 180 command in
sip-ua configuration mode. To enable early media cut-through for 180 messages with SDP, use the no
form of this command. disable-early-media 180
config t
sip-ua
Re: Outbound Ringback Issues over SIP trunk using CUCM 8.6 and H
I added the disable-early-media 180 with no luck.  attached is a copy of debug ccsip messages.  What do i need to do to enable Annunciator and assign it to phones/gateway?  Ive never done that before.
OK i have ANN_2 and ANN_3 under Announciator, i put them in a group then put them in a list.  On my gateway i applied the list and checked MTPR checkbox.  I selected the Media Resource Group list under my phones and device pool.  I also went to Service Parameters and set
Any more ideas or debugs you guys want?
VIP Super Bronze
You dont need to check MTP box. Please uncheck otherwise you may create additional problems..
Can you do a test call and send me a
show voip rtp connection  (this will show us if the annunciator is been called upon to provide ringback)
NB: to see the annuciator in the voip rtp connection command to need to be refreshing the command. Dont just call and type the command once. Because the ann is called when its time to provide ringback.
also please send a full debug ccsip messages. The one you sent, the call did not complete
Do oyu know how to collect cucm traces? If you can send that will be great.
VIP Super Bronze
John,
Have you made any progress with this? Did you see my last post
Havent had a chance to run through this yet.  Will tonight and post results that you requested.  Im not too familiar with CUCM traces
Hi All,
Hi All,
Even i have the same issue . There will be one ring then then a fax tone then it will give a message" We are sorry your call cannot be completed this time, please hang up and dial after sometime" this message will play twice in quick session of two times and then the call will disconnect. The call is reaching the gateway .
Working calls are receiving 183 message with SDP but the failing calls from this location does not have 183 instead it have 180 without any SDP message in it  and getting a 200 OK message soon.
Is it ok for us to involve ITSP.
Shinaj cm
VIP Super Bronze
You should engage your ITSP
You should engage your ITSP and I hope it is not TATA. Provide traces to them and push them to look at why you are seeing this behaviour
Hi Ayodeji,
Hi Ayodeji,
Customer is asking why it is service provider issue as all the numbers are going to the same provider and it is working.
this is occurring only for a set or block of DID.
Shinaj cm
Here is the requested output.  Anytime you see the output of show voip rtp connection it is when the outbound call should be providing ringback, and the number i am calling is ringing on the other end.
In the mean time i have also tried this:
System > Service Parameters > Under Clusterwide Parameters (Device - H323) set Check Progress Indicator Before Establishing Media to True (False as default) and setting Send H323 User Info Message to H225 Info for Call Progress Tone, restarted callmanager service, reset the gateway, all with no luck.
VIP Super Bronze
John,
Looking at your trace I dont see the communication with CUCM. I dont see your gateway receiving an invite from cucm or sending sip trying or 200 ok to cucm. If the call originated from cucm then this must happen.
Did you omit this traces?
No those were from the router and nothing was omitted.  Were those suppose to come from CUCM traces?
VIP Super Bronze
John,
I know why I dont see the trace, its beacise the leg to cucm is h323 leg, its not sip.
May I ask, why are you not using SIP all the way.? i.e. configure your sip trunk from cucm to your gateway. Have you tried this.
Let me know if you want to try with the sip trunk setup. Otherwise please do another test call and send
debug voip ccapi inout.
I would try converting it to SIP the whole way.  How do i go about configuring that in CUCM and on the router>?
Just kidding, it looks like i just need to switch the session protocol to sipv2 then setup a trunk instead of a gateway on CUCM
VIP Super Bronze
voice servie voip
sip
options-ping 60
voice-class codec 1
dtmf-relay rtp-nte
problem im running into now, is that when i bind the sip source interface to the internal FA port rather than the external, now my sip trunk does not register
how can i bind it to the external AND internal interface so it will register and work as a cucm trunk?
VIP Super Bronze
John,
What do you mean by your sip trunk does not register? Are you talking about cucm trunk? or the sip trunk to your provider?
CUCM sip trunk does not register and as far as I know, your ITSP trunk does not register. Most ITSP use authentication.
Can you send a sh run of your router...
The show run is attached in the zip file in the first post
when i do a show sip-ua register status it shows up as registered: YES
if i bind sip to the internal interface it shows registered: NO and no calls work in or out
when i did a debug ccsip messages, its sending the SIP provider my internal IP address, which obviously isnt going to work (when bound to the inside interface)
VIP Super Bronze
John,
OK I get you now. I did not know you were using a registrar.
Can you leave your bind on your external interface...Try and send a call to the cube..Let me know what happens. CUCM trunk does not need registration.
OK.  I bound SIP to the internal interface and setup the SIP traffic to route out my ASA gateway and setup static statements on the ASA to map the SIP traffic to the router behind it and viola, everything is working once i converted cucm to the sip trunk.
Thanks for the help aokanlawon
Re: Outbound Ringback Issues over SIP trunk using CUCM 8.6 and H323
Make sure the annunciator is inside the MRG of the SIP trunks. I left my ANN inside a not-used MRG, and after put it in the MRG of the SIP trunk, I got the ringback.
Hi Ayodeji, I had the same
Hi Ayodeji,
I had the same problem that JZergers06 had and I disabled the early media 180, as you said on pots above and everything worked fine. Thanks a lot!!!
Hello Ayodeji,
Hello Ayodeji,
I always enjoy reading your posts..Very very informative and i admire your passion on the SIP technology.
Regarding "If you are receiving 183 with SDP but still not getting ringback,",
1. what can cause this issue ?
2. What is the side effect of disabling early media on other call flows ?
3. Is it a good idea or valid idea to translate 183 with sdp to 180 ringing on the SBC to do the same ?
Thanks,Padhu
VIP Super Bronze
Thank you for your kind words
Thank you for your kind words..
1. It is usually a problem on the service provider side. So there is nothing much you can do other than contacting them
2. You will typically not get announcements that are played before media connects. Anything that is sent as media before 200 OK or ACK is early media and if you disable it, then you don't get it
3. It is advisable to let SBC/service provider do it. It is not recommended practice..
Thank you Ayodeji.
Thank you Ayodeji.
Disabling early media didn't seem to fix but some interesting things in the cm traces and sdp.
(Sip trunk set for early offer with insert MTP if reqd)
when phones have g711 ahead of g729 in ACPL ( same in SDP), the ring back works but ringback fails when G729 is chosen first. CCm Traces indicate a SW_MTP being allocated eventhough MRGL has MRGs with HW_IOS_MTP higher up in the order...So that brings up an anamoly where a G711 based SW MTP being invoked for a G729 call and ring back fails.
we are investigating more on this choice of MTP.
I am having the exact same issue. When G729 is negotiated the ringback fails (though the call succeeds).
Did you find any solution to it?
11494
