outbound translation - Internal extension to External PSTN number
I have Cisco cube deployment 2911 with SIP trunk to an ISP.
How do I setup so that when users dial ext 3476, it automatically dials a PSTN number 1 (714) 781-7277
JayP
Hi,You can create a
You can create a translation pattern in CUCM to convert the number from 3476 to 1 (714) 781-7277.
//Suresh
//Suresh Please rate all the useful posts.
Thanks! can this be done on
Thanks! can this be done on the 2911 instead ? not sure if this can be done, an example would be helpful.
Jayp
Hello Jay, yes, the same can
Hello Jay,
yes, the same can be done with translation-rules applied on the inbound dial-peers.
how do you send that number 3476 to CUBE? is it not the internal extension?
refer the below link for better understanding of translation rules and translation profiles.
http://www.cisco.com/c/en/us/support/docs/voice/call-routing-dial-plans/64020-number-voice-translation-profiles.html#
//Suresh
Please rate all the helpful posts.
HI,I guess, I am not
HI,
I guess, I am not understanding this clearly. I read the link provided and still not clear.
This number 3476 is not an extension, nor a DID and is not used in the office.  It is just a number manager has chosen. Basically, when someone dials this number 3476 in the office,  manager wants this number to call 1 (714) 781-7277 which is an outbound call to Disneyland. Office has a SIP trunk with ITSP. Can this be accomplished on the 2911 cube router and how ?
JayP
Hello Jay, I'd still say
Hello Jay,
I'd still say configuring the translation pattern in CUCM for this change is a better and easy way.
if you still want to do it on the CUBE, please try the configuration below. (I presume the number 3476 will reach from CUCM to CUBE directly without any modification)
>> Create the translation rule to change the number
voice translation-rule 1
rule 1 /3476/ /17147817277/
>> create the translation profile and apply the rule to change the called numbers
voice translation-profile Change3476
translate called 1
>> Apply this translation profile command "translation-profile incoming Change3476" to the inbound dial-peer from CUCM.
>> you can test the translation rule as below
Router#test voice translation-rule 1 3476
//Suresh
VIP Gold
or you can do it using "num
or you can do it using "num-exp 3476 17147817277" in global mode of gateway.
This will be applied globally.
Suresh
I tried all the suggestions
I tried all the suggestions and still does not work.
JayP
VIP Gold
Can you post the call flow in
Can you post the call flow in your deployment for this call ?
Suresh
106
