08-17-2009 02:11 AM - edited 03-15-2019 07:23 PM
Pls help i am currently having three PRI in h.323 setup on single gateway and CUCM 6.1.How can i loadbalance oubound voice calls on all the three PRI.If any sample config available pls share.
Solved! Go to Solution.
08-17-2009 05:40 AM
Configure a route group with Distribution Algorithm = Circular
java
if this helps, please rate
08-17-2009 04:23 AM
Under controller, put them in a trunk group with a name of your choice.
Reference said trunk group under pots DP instead of port.
You can also configure hunt schemes under trunk group configuration mode.
08-17-2009 05:33 AM
Thanks for the solution..
08-17-2009 07:29 AM
You are welcome, please remember to rate useful posts with the scrollbox below.
08-17-2009 05:37 AM
Hi can u pls suggest in case of MGCP how we can configure it on CUCM..
08-17-2009 05:40 AM
java
08-20-2009 09:52 PM
Thanks for the solution.I am facing another problem pls help .
How to configure load balacing with CUCM in gateway.
For example: Suppose I have dial-pattern x.x.x.x and three CallManager Pub,sub1 & sub2 in this case I have to configure preference in each dial-peer to select the
CallManager for incoming calls from PSTN on gateway.
In above configuration next CallManger is used only when first CallManager is not available.
Is there any way to configure so that first incoming call will go to first CUCM,2nd call will go to 2nd CUCM and so on
