11-07-2014 10:46 AM - edited 03-17-2019 12:50 AM
Hi All,
we have almost done with the config of the UC540 IP System. We are able to make internal call. We need now to handle the outgoing and incoming calls.
how to :
The system is UC540W with 4 FXO ports (analog line).
We have 2 land lines phone (0302500325 ; 0302500326) & 1 International line (0302500324)
Thanks in advance !²
11-09-2014 11:15 PM
I suggest you follow the below pdf.
http://www.cisco.com/c/en/us/td/docs/ios/voice/dialpeer/configuration/guide/12_4t/vd_12_4t_book/vd_dp_cfg_examp.pdf
Rate for Gods sake!!!!.
11-25-2014 10:24 AM
I read the doc and build my config.
We are able to receive calls coming IN on each of the phone number. But we make call.
The phone say "Line Busy" all the time. Can you help me to understand the issue ?
Bellow the config :
voice translation-rule 1
rule 1 /^86/ //
rule 2 /^87/ //
rule 3 /^88/ //
voice translation-rule 2
rule 1 /0302500324/ /100/
rule 2 /0302500325/ /104/
rule 3 /0302500326/ /105/
voice translation-profile GH-IN
translate calling 2
voice translation-profile GH-OUT
translate called 1
voice-port 0/1/0
trunk-group ALL_FXO 64
translation-profile incoming GH-IN
translation-profile outgoing GH-OUT
supervisory disconnect dualtone mid-call
cptone GH
timeouts call-disconnect 2
timeouts wait-release 2
connection plar opx 100
description Line VODAFONE 0302 544 324
caller-id enable
voice-port 0/1/1
cptone GH
connection plar opx 104
description Line VODAFONE 0302 544 325
caller-id enable
voice-port 0/1/2
cptone GH
connection plar opx 105
description Line VODAFONE 0302 544 326
caller-id enable
dial-peer voice 54 pots
description **International Call**
destination-pattern 88.T
port 0/1/0
forward-digits all
no sip-register
dial-peer voice 55 pots
description ** National Calls **
destination-pattern 87..........
port 0/1/1
forward-digits 10
no sip-register
dial-peer voice 56 pots
destination-pattern 86..........
port 0/1/2
forward-digits 10
no sip-register
11-25-2014 10:27 AM
A voice says the line is busy or are you getting a busy tone?
11-25-2014 01:05 PM
Busy tone, with "Busy" word on the screen
12-02-2014 11:40 PM
I'm assuming that the call was made from Internal to PSTN.
Please post the number your dialing and the debug below.
Debug:
debug voice ccapi inout
debug voip dialpeer inout
Please make sure that you use the debug commands one a time.
11-26-2014 06:10 PM
Fixed now :)
But when we receive a call from isdn, we have UNKNOWN NUMBER
any ideas ?
12-02-2014 11:35 PM
If your receving unknown numbers, input the below config and use the below debug on the router.
voice-port x/x/x/
caller-id enable
Debug:
debug vpm signal(post output.
