Outgoing and Incoming Call on UC540
Hi All,
we have almost done with the config of the UC540 IP System. We are able to make internal call. We need now to handle the outgoing and incoming calls.
how  to :
  • Configure the ‘voice translation-rule’ ,  the “voice translation profile”  the  “dial-peer   pots”  and “translation profile” for national call
  • Configure the ‘voice translation-rule’ ,  the “voice translation profile”  the  “dial-peer   pots” and the “translation profile” for international call
The system is UC540W with 4 FXO ports (analog line).
We have 2 land lines phone (0302500325 ; 0302500326) & 1 International line (0302500324)
Thanks in advance !²
  • IP Telephony
Hi, I suggest you follow the
I suggest you follow the below pdf.
http://www.cisco.com/c/en/us/td/docs/ios/voice/dialpeer/configuration/guide/12_4t/vd_12_4t_book/vd_dp_cfg_examp.pdf
Rate for Gods sake!!!!.
Hi,I read the doc and  build
I read the doc and  build my config.
We are able to receive calls coming IN on each of the phone number. But we make call.
The phone say "Line Busy" all the time.  Can you help me to understand the issue ?
Bellow the config :
voice translation-rule 1
 rule 1 /^86/ //
 rule 2 /^87/ //
 rule 3 /^88/ //
voice translation-rule 2
 rule 1 /0302500324/ /100/
 rule 2 /0302500325/ /104/
 rule 3 /0302500326/ /105/
voice translation-profile GH-IN
 translate calling 2
voice translation-profile GH-OUT
 translate called 1
voice-port 0/1/0
 trunk-group ALL_FXO 64
 translation-profile incoming GH-IN
 translation-profile outgoing GH-OUT
 supervisory disconnect dualtone mid-call
 cptone GH
 timeouts call-disconnect 2
 timeouts wait-release 2
 connection plar opx 100
 description Line VODAFONE 0302 544 324
 caller-id enable
voice-port 0/1/1
 cptone GH
 connection plar opx 104
 description Line VODAFONE 0302 544 325
 caller-id enable
voice-port 0/1/2
 cptone GH
 connection plar opx 105
 description Line VODAFONE 0302 544 326
 caller-id enable
dial-peer voice 54 pots
 description **International Call**
 destination-pattern 88.T
 port 0/1/0
 forward-digits all
 no sip-register
dial-peer voice 55 pots
 description ** National Calls **
 destination-pattern 87..........
 port 0/1/1
 forward-digits 10
 no sip-register
dial-peer voice 56 pots
 destination-pattern 86..........
 port 0/1/2
 forward-digits 10
 no sip-register
A voice says the line is busy
A voice says the line is busy or are you getting a busy tone?
Busy tone, with "Busy" word
Busy tone, with "Busy" word on the screen
I'm assuming that the call
I'm assuming that the call was made from Internal to PSTN.
Please post the number your dialing and the debug below.
Debug:
debug voice ccapi inout
debug voip dialpeer inout
Please make sure that you use the debug commands one a time.
Fixed now  :) But when we
Fixed now  :)
But when we receive a call from isdn, we have   UNKNOWN NUMBER
any ideas ?
If your receving unknown
If your receving unknown numbers, input the below config and  use the below debug on the router.
voice-port x/x/x/
caller-id enable
Debug:
debug vpm signal(post output.
70
