Outgoing call for faxes connected on FXS ports
I have an UC500 and incoming calls works to the fax machine but outgoing doesn not work. I thought it should go on the outgoing dial-peer created. Is this wrongly configured?
Re: Outgoing call for faxes connected on FXS ports
try adding 'no vad' to your two voip dial peers.
Other than that, it should be fine.
hth,
nick
I added it to the voip dial peers. Incoming works just fine but not outgoing. I dont even get an dialtone. Could it be some codec problem?
I added it to the voip dial peers. Incoming works just fine but not outgoing. I dont even get an dialtone. Could it be some codec problem.
114
