outgoing call number display
All,
We have a C2851 voice gateway connecting two PRIs with Verizon. The issue is, all our outgoing calls are showing from only one number. We have checked with Verison and they said they have everything all our numbers in their database and we will need to do something on our side. We just migrated from Paetec and we did not need to configure anything before. I am confused. Can you guys help?
Hall of Fame Super Gold
Re: outgoing call number display
Post output of "debug isdn q931" with "term mon". You can mask some digits with X if you whish.
You also need to mention if using MGCP or H.323.
We are using MGCP.
Thanks!
hse-ny-vgw-01#debug isdn q931
debug isdn q931 is ON.
hse-ny-vgw-01#
.Oct 15 21:38:36.701: ISDN Se0/0/0:23 Q931: TX -> SETUP pd = 8 callref = 0x086C
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98397
Exclusive, Channel 23
Calling Party Number i = 0x4181, '0337'
Plan:ISDN, Type:Subscriber(local)
Called Party Number i = 0x80, '15555555555'
Plan:Unknown, Type:Unknown
.Oct 15 21:38:36.897: ISDN Se0/0/0:23 Q931: RX <- CALL_PROC pd = 8 callref = 0x886C
.Oct 15 21:38:38.273: ISDN Se0/0/0:23 Q931: RX <- PROGRESS pd = 8 callref = 0x886C
Progress Ind i = 0x8288 - In-band info or appropriate now available
.Oct 15 21:38:51.034: ISDN Se0/0/0:23 Q931: TX -> DISCONNECT pd = 8 callref = 0x086C
Cause i = 0x8090 - Normal call clearing
.Oct 15 21:38:51.074: ISDN Se0/0/0:23 Q931: RX <- RELEASE pd = 8 callref = 0x886C
.Oct 15 21:38:51.090: ISDN Se0/0/0:23 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x086C
hse-ny-vgw-01#
hse-ny-vgw-01#u all
All possible debugging has been turned off
hse-ny-vgw-01#
Sorry I don't know the exact steps, basically you have to configure CM for and external mask with that makes 10 digits, set plan/type to either isdn/national, or unknown/unknown.
242
