outgoing call problem
hi,
im not able to make call from CME to PSTN network .. while calling the result of debug isdn q931 is
" Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98382
Exclusive, Channel 2
Progress Ind i = 0x8183 - Origination address is non-ISDN
Calling Party Number i = 0x0180, '17317400'
Plan:ISDN, Type:Unknown
Called Party Number i = 0x81, '39325303'
Oct 12 15:10:17.655: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref =
0x0092
Cause i = 0x80E6 - Recovery on timer expiry
Oct 12 15:10:17.655: ISDN Se0/0/0:15 **ERROR**: CCPCC_CallOrigination: SETUP tim
ed-out (2nd T303) to NETWORK. The SETUP failed.
Oct 12 15:10:18.423: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref =
0x0093
Oct 12 15:10:18.423: ISDN Se0/0/0:15 **ERROR**: CCPCC_CallOrigination: SETUP tim
ed-out (2nd T303) to NETWORK. The SETUP failed."
this is my first installation, i have done configuration on CME according to docs, i dont know either its my prob or from service provider ... can any one help me out please
thanks in advance
REgards
Re: outgoing call problem
Looking at the logs problem looks to be in the Service Provider side. (Although i am missing part of the logs...).
Assuming that the SETUP is sent by the CME, there is no reply from the SP side, and thus the call is released after the timer expired, probably after 4 seconds. T303 timer.
For us to help you, post some more info.
Result of 'show isdn status'
What country?
Relevant parts of the Running config
result of show isdn status is
UNDP-CCME#sh isdn status
Global ISDN Switchtype = primary-net5
ISDN Serial0/0/0:15 interface
dsl 0, interface ISDN Switchtype = primary-net5
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0x80000FFF
Number of L2 Discards = 0, L2 Session ID = 2
Total Allocated ISDN CCBs = 0
UNDP-CCME#
and the result of debug isdn q921 is
UNDP-CCME#
Oct 13 08:58:38.367: ISDN Se0/0/0:15 Q921: User TX -> RRp sapi=0 tei=0 nr=0
Oct 13 08:58:38.367: ISDN Se0/0/0:15 Q921: User RX <- RRp sapi=0 tei=0 nr=9
Oct 13 08:58:38.367: ISDN Se0/0/0:15 Q921: User TX -> RRf sapi=0 tei=0 nr=0
Oct 13 08:58:38.375: ISDN Se0/0/0:15 Q921: User RX <- RRf sapi=0 tei=0 nr=9
Oct 13 08:58:41.075: ISDN Se0/0/0:15 Q921: User TX -> INFO sapi=0 tei=0, ns=9 nr
=0
Oct 13 08:58:41.087: ISDN Se0/0/0:15 Q921: User RX <- RR sapi=0 tei=0 nr=10
Oct 13 08:58:45.071: ISDN Se0/0/0:15 Q921: User TX -> INFO sapi=0 tei=0, ns=10 n
r=0
Oct 13 08:58:45.083: ISDN Se0/0/0:15 Q921: User RX <- RR sapi=0 tei=0 nr=11
Oct 13 08:58:49.071: ISDN Se0/0/0:15 Q921: User TX -> INFO sapi=0 tei=0, ns=11 n
r=0
Oct 13 08:58:49.071: ISDN Se0/0/0:15 **ERROR**: CCPCC_CallOrigination: SETUP tim
Oct 13 08:58:49.079: ISDN Se0/0/0:15 Q921: User RX <- RR sapi=0 tei=0 nr=12
UNDP-CCME#
UNDP-CCME#
my running config is
"controller E1 0/0/0
framing NO-CRC4
pri-group timeslots 1-10,16 (bcoz the customer has 10channels in 1 PRI)"
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn incoming-voice voice
isdn bchan-number-order ascending
no cdp enable
voice-port 0/0/0:15
translation-profile incoming IncomingPSTN
translation-profile outgoing DIDOUT
dial-peer voice 21 pots
destination-pattern 9[1-8].......
direct-inward-dial
port 0/0/0:15
forward-digits 8
im doing this project in Bahrain and my provider name is Batelco ...
if any more info required then tell me ..
thanks for reply
is 17317400 a valid number to be send to pstn as ur number i mean calling number ?
were u looking to call '39325303' as called number?
can u post ur config
the calling number 17371400 that should be valid,because my customer has got this number from service provide...and according to the communication between customer and provider,provider have fix this number on there side.and called number 39325303,this is my mobile number.so i am trying to call from that ip phone with extension 400 to my mobile number..well my running config is
UNDP-CCME#sh run
Building configuration...
version 12.4
hostname UNDP-CCME
boot-start-marker
boot-end-marker
card type e1 0 0
logging buffered 51200 warnings
clock timezone GMT 3
network-clock-participate wic 0
ip cef
ip domain name undp.org.bh
ip name-server 192.168.1.3
voice-card 0
dspfarm
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
h323
sip
registrar server expires max 3600 min 3600
voice class codec 1
codec preference 1 g711ulaw
voice register global
max-dn 192
max-pool 48
voice translation-rule 100
rule 1 /^17317/ //
voice translation-rule 200
rule 1 // //
voice translation-profile DIDOUT
translate calling 200
voice translation-profile IncomingPSTN
translate called 100
controller E1 0/0/0
framing NO-CRC4
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.10
description ** Voice VLAN **
encapsulation dot1Q 10
ip address 192.168.10.2 255.255.255.0
interface GigabitEthernet0/0.100
description ** Data VLAN **
encapsulation dot1Q 100
ip address 192.168.1.14 255.255.255.0
interface Service-Engine0/0
ip unnumbered Loopback0
service-module ip address 10.1.10.1 255.255.255.0
service-module ip default-gateway 10.1.10.2
interface GigabitEthernet0/1
ip address 10.0.0.1 255.255.255.0
duplex auto
speed auto
no ip address
encapsulation hdlc
no cdp enable
ip route 0.0.0.0 0.0.0.0 192.168.10.1 permanent
ip route 10.1.10.1 255.255.255.255 Service-Engine0/0
ip http server
ip http access-class 23
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip http path flash:
voice-port 0/0/0:15
dial-peer voice 10 voip
description ** cue voicemail pilot number **
translation-profile outgoing PSTN_CallForwarding
destination-pattern 600
session protocol sipv2
session target ipv4:10.1.10.1
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 11 voip
description ** cue auto attendant number **
destination-pattern 601
codec g711ulaw
no vad
no digit-strip
direct-inward-dial
port 0/0/0:15
forward-digits 8
dial-peer voice 22 pots
description Internation Access
destination-pattern 900T
direct-inward-dial
port 0/0/0:15
prefix 00
telephony-service
load 7960-7940 P00308000500
load 7914 S00104000100
load 7970 term70.default
max-ephones 48
max-dn 96
ip source-address 192.168.10.2 port 2000
calling-number initiator
system message UNDP
time-zone 31
date-format dd-mm-yy
voicemail 600
max-conferences 8 gain -6
call-forward pattern .T
moh music-on-hold.au
multicast moh 239.10.16.4 port 2000
dn-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern 9.T
secondary-dialtone 9
login timeout 5
create cnf-files version-stamp 7960 Oct 13 2008 10:06:40
thanks for reply.
can u apply the translation profile on the dial-peers instead of the voice port
remove it from the voice port then apply it as following
incoming-called number .
and can u tell me if if u use dial-plan pattren or not i cant see anyway
and do all ur internal phones have DID number ?
can u describe the following to me ?
rule 1 // //
thenk you and good luck
hi marwan .. thanks for reply bro ....about the testing for translation profile in dial peer i will check out by today .... and about translation rule which was in my config that was fake (i make that rule because of limited characters on post) well my translation rule is simple
rule 1 /^17317400/ /400/
rule 1 /^400/ /17317400/
about DID, as i told the customer has got 10Channels from 1 PRI so i think customer can get 10 DID at a time .....but DID i have to configure it is into scope of my work ...
Hi all,
this issue has been fixed ... the problem was from service provider side ... they people had block outgoing from there side ... thats why i was not able to call ... well thank you so much for all and for there time ... this was my first post on netpro and got perfect suggestion from all of you guyz ... thanks once again ...
will see you with some other issue ;)
710
