Outgoing calls are not working through SIP trunk
DebugHi
I have CUCM8.6 and Voice gateway that are connected through SIP Trunk to Teleco or MOC
it is giving me bust tone when i am tring call outside through sip trunk
Note : E1 module and FXO module  are not used or not available , the call is going from my voice router to Teleco Router to go outside
DID ext : 22270800 to 899
why i cant call outside ???? how to solve it ???
below the configuration and debug
the configuration is
card type e1 0 3
enable secret 4 gMj8cDXfU6CzFI9r1WoD5G6GTI5KwVY2O2lU2DSTP4c
no aaa new-model
network-clock-participate wic 3
no ipv6 cef
ip source-route
ip cef
isdn switch-type primary-net5
voice-card 0
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
  bind control source-interface GigabitEthernet0/0
  bind media source-interface GigabitEthernet0/0
license udi pid CISCO2901/K9 sn FCZ1624711H
hw-module pvdm 0/0
redundancy
controller E1 0/3/0
pri-group timeslots 1-31
interface Embedded-Service-Engine0/0
no ip address
shutdown
description ## Connected to Fasttlco P2P ##
ip address 10.101.6.18 255.255.255.252
duplex auto
speed auto
interface GigabitEthernet0/1
description ## Internal Network ##
ip address 10.10.1.5 255.255.255.0
duplex auto
speed auto
interface Serial0/3/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
no cdp enable
router rip
version 2
network 10.0.0.0
no auto-summary
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/3/0:15
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
voice-port 0/2/0
voice-port 0/2/1
voice-port 0/2/2
voice-port 0/2/3
mgcp profile default
dial-peer voice 10 voip
destination-pattern 8..
session protocol sipv2
session target ipv4:10.200.200.50
incoming called-number .
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 11 pots
destination-pattern 9.T
progress_ind setup enable 3
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
direct-inward-dial
port 0/3/0:15
gatekeeper
shutdown
Debug is
Sep  1 20:20:04.630: //41/8017470F1100/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
Sep  1 20:20:04.630: //41/8017470F1100/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x3101F7A4, Tag=0x0, Call Id=41,
   Call Entry(Disconnect Cause=21, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
Sep  1 20:20:04.630: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Sep  1 20:20:04.630: :cc_free_feature_vsa freeing 2B3F72C8
Sep  1 20:20:04.630:  vsacount in free is 0
Sep  1 20:20:21.794: //-1/001669191200/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=22270840
   ----- ccCallInfo IE subfields -----
   cisco-ani=22270840
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=924950500
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Sep  1 20:20:21.794: //-1/001669191200/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x3101F7A4, Call Info(
   Calling Number=22270840,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=924950500(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=10, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=42
Sep  1 20:20:21.794: //-1/001669191200/CCAPI/ccCheckClipClir:
   In: Calling Number=22270840(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
   Out: Calling Number=22270840(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Sep  1 20:20:21.794: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Sep  1 20:20:21.794: :cc_get_feature_vsa malloc success
Sep  1 20:20:21.794:  cc_get_feature_vsa count is 1
Sep  1 20:20:21.794: :FEATURE_VSA attributes are: feature_name:0,feature_time:725578448,feature_id:42
Sep  1 20:20:21.794: //42/001669191200/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=22270840(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=924950500(TON=Unknown, NPI=Unknown))
Sep  1 20:20:21.794: //42/001669191200/CCAPI/cc_process_call_setup_ind:
   Event=0x2B7C9F18
Sep  1 20:20:21.794: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 924950500
Sep  1 20:20:21.794: //42/001669191200/CCAPI/ccCallSetContext:
   Context=0x2ADBAE4C
   >>>>CCAPI handed cid 42 with tag 10 to app "_ManagedAppProcess_TOLLFRAUD_APP"
Sep  1 20:20:21.794: //42/001669191200/CCAPI/ccCallDisconnect:
   Cause Value=21, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
   Cause Value=21, Call Entry(Responsed=TRUE, Cause Value=21)
Sep  1 20:20:21.794: //42/001669191200/CCAPI/cc_api_get_transfer_info:
Sep  1 20:20:21.794: //42/001669191200/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x3101F7A4, Tag=0x0, Call Id=42,
Sep  1 20:20:21.794: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Sep  1 20:20:21.794: :cc_free_feature_vsa freeing 2B3F72C8
thanks and regards
1 REPLY
There was another post from alex today responding to the same issue. Here is the extract from his post:
This disconnect is because of the tall fraud prevention.
"You may try adding the following:
voice service voip
 ip address trusted list
  ipv4 0.0.0.0 0.0.0.0
But it is good to fill with specific servers.
Please take a look at the following link about tall fraud prevention:
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a0080b3e123.shtml
Link to the Post: https://supportforums.cisco.com/message/3723154#3723154
755
