Community Member
Outgoing Calls are OK, incoming calls not being set to the phone via ISDN
Hi, i have an ISDN telco box connected to my ISDN BRI NT/TE card using a straight cable.
My config file is working for the outgoing calls, the incoming voice calls do not get terminated to the phone assigned by the "connection plar" command. (somehow this command is ignored by the router).
I have attached the config and debug isdn txt files to the question. I have removed some unnecessary lines like tftp-server to be more easy to understand.
The router has the following cards:
VIC2-2FXS
VIC2-2FXO
VIC2-BRI NT/TE
PVDM2-8
Any help is much appreciated!
If you need some further info i will post them.
Community Member
Re: Outgoing Calls are OK, incoming calls not being set to the p
Can someone please help?
Bronze
Are you able to do a debug voice ccapi inout and see what dial peers it hits
Paul
106
