Outgoing calls failing with fast busy - DisconnetText bearer capability not authorized
        We have a site where everything was great.  The ISP needed to change IP range.  Everything was switched over, but now outbound calls are failing with a fast busy.
SIP provider is saying it is our configuration.
Feb 27 19:36:11.289: //371/3B783BC98334/SIP/Media/sipSPIDestroyRtpSession: stream:4C3C3A54
Feb 27 11:36:11.289: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 2, ConnectionId 3B783BC99F1D11E38334F8412816B2, SetupTime 11:36:11.219 Pacific Thu Feb 27 2014, PeerAddress 3603891065, PeerSubAddress , DisconnectCause 39  , DisconnectText bearer capability not authorized (57), ConnectTime 11:36:11.289 Pacific Thu Feb 27 2014, DisconnectTime 11:36:11.289 Pacific Thu Feb 27 2014, CallOrigin 1, ChargedUnits 0, InfoType 2, TransmitPackets 0, TransmitBytes 0, ReceivePackets 0, ReceiveBytes 0
Feb 27 11:36:11.293: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:02/27/2014 11:36:11.201,cgn:xxx7462629,cdn:xxx3891065,frs:0,fid:523,fcid:3B783BC99F1D11E38334F8412816B2,legID:173,bguid:3B783BC99F1D11E38334F841002816B2
Feb 27 19:36:11.297: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
I x'd out the area code.
1 REPLY
Please work thru the following threads and see if it helps you.
It be that this is happening because the extension is not registered in SIP provider.
https://supportforums.cisco.com/thread/2046038
Voice CCIE #37771
632
