Outgoing calls issue
*Jun 27 10:19:53.715: ISDN BR0/1/0 Q931: Applying typeplan for sw-type 0x1 is 0x0 0x0, Calling num 0113252322
*Jun 27 10:19:53.719: ISDN BR0/1/0 Q931: Applying typeplan for sw-type 0x1 is 0x0 0x0, Called num 0119129300
*Jun 27 10:19:53.747: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0/1/0, TEI 73 changed to up
*Jun 27 10:19:53.747: ISDN BR0/1/0 Q931: TX -> SETUP pd = 8 callref = 0x13
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x81
Calling Party Number i = 0x0080, '0113252322'
Plan:Unknown, Type:Unknown
*Jun 27 10:19:53.851: ISDN BR0/1/0 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x93
Cause i = 0x82C1 - Bearer capability not implemented
Any ideas? Let me know if you want the config, thanks
Re: Outgoing calls issue
The problem is due to this -
This means the call is using ulaw coding and I would guess you are not located in North America.
Add the following command under voice-port 0/1/0
compand-type a-law
I would also suggest you add the following commands (in case you don't already have them) to ensure the DSP's are clocked off the BRI port -
network-clock-participate wic 0
network-clock-select 1 bri 0/1/0
This will fix faxing or modem issues that you may never know you had :-)
that's a good one!
Chad
Hall of Fame Super Gold
Missed this one .. 5 points to Paul for combining two all-time favorites in a single answer :)
Yeah! Thanks okes, umm... 5 to you! Thanks, am going to test now. Will post results...
Yip, executed the changes and also had to put the progree indicator and progress alerting on, am now able to make outgoing calls, however need to implement CoR now :)
306
