outgoing calls not showing the correct numbers
Hi All,
please advise on this.
I have a router with 4 BRI and the client require to see their own number when they dialing out instead of main number.
from debug isdnq931 i see the router already send the correct number 97775882 but on the receipt it shows 97775880 instead.
Aug  7 10:30:46.422: ISDN BR0/0/0 Q931: Sending SETUP  callref = 0x000C callID = 0x802B switch = vn3 interface = User
Aug  7 10:30:46.422: ISDN BR0/0/0 Q931: TX -> SETUP pd = 8  callref = 0x0C
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0x81
                Preferred, B1
        Shift to Codeset 6
        Codeset 6 IE 0x24  i = 0x80
        Progress Ind i = 0x8183 - Origination address is non-ISDN
        Display i = ''
        Calling Party Number i = 0x2180, '037797775882'
                Plan:ISDN, Type:National
        Called Party Number i = 0xA1, '0033623864219'
        High Layer Compat i = 0x9181
        Sending Complete
Aug  7 10:30:46.794: ISDN BR0/0/0 Q931: RX <- CALL_PROC pd = 8  callref = 0x8C
        Channel ID i = 0x89
                Exclusive, B1
Aug  7 10:30:55.770: ISDN BR0/0/0 Q931: RX <- ALERTING pd = 8  callref = 0x8C
Aug  7 10:31:10.198: ISDN BR0/0/0 Q931: TX -> DISCONNECT pd = 8  callref = 0x0C
        Cause i = 0x8790 - Normal call clearing
Thanks & Regards
2 ACCEPTED SOLUTIONS
So 97775880 which is the central number of your circuit only appear.Based on your debugs , your call match correct translation-rule , and hit correct dial-peer and if you see when you dial from 5886. So you have to check with your teleco that caller id should be enable from his side and you do not have any issues.
Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=6, Params=0x21EBC32C, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
Aug  7 11:07:59.202: //184/E82287BA81BE/CCAPI/ccCheckClipClir:
   In: Calling Number=037797775886
And we can see below that your call go out with the correct caller id.
                Standard = CCITT
        Channel ID i = 0x81
                Preferred, B1
        Shift to Codeset 6
        Display i = 'Paolo Gatti'
        Calling Party Number i = 0x2180, '037797775886'
        Called Party Number i = 0xA1, '0041791981218'
        Sending Complete
please rate all useful information
Hi, you should talk to your
Hi, you should talk to your Telco on this issue as you are sending the correct number out
//Suresh Please rate all the useful posts.
                Standard = CCITT
        Channel ID i = 0x81
                Preferred, B1
        Shift to Codeset 6
        Sending Complete
90
