Outgoing Calls SIP Provider (CME)
i have a problem with outgoing calls on my CME router. I don`t know why. :-/ Incoming works well. I think i missed some little think but i don`t know what.
Here is the config and debug.
**CONFIG**
voice call send-alert
voice call convert-discpi-to-prog
voice call carrier capacity active
voice rtp send-recv
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
redirect ip2ip
fax protocol pass-through g711alaw
h323
modem passthrough nse codec g711alaw
sip
  bind control source-interface FastEthernet0/0
  session transport tcp
  registrar server expires max 3600 min 3600
  redirect contact order best-match
  localhost dns:sipgate.de
voice class codec 1
codec preference 1 g711alaw
voice translation-rule 3
rule 1 /^0/ /+49/
voice translation-rule 4
rule 1 /^1001/ /004930129854765/
voice translation-rule 11
rule 1 /^/ /0/ type unknown unknown
rule 2 /^/ /00/ type national national
rule 3 /^/ /000/ type international international
voice translation-rule 12
rule 1 /^004930129854765/ /1001/
voice translation-profile SIP-Incoming
translate calling 11
translate called 12
voice translation-profile SIP-Outgoing
translate calling 4
translate called 3
dial-peer voice 11 voip
description **Incoming Call**
translation-profile incoming SIP-Incoming
session protocol sipv2
session target dns:sipgate.de
incoming called-number .%
voice-class codec 1
voice-class sip dtmf-relay force rtp-nte
dtmf-relay rtp-nte
no vad
dial-peer voice 10 voip
description **Outgoing Call**
translation-profile outgoing SIP-Outgoing
destination-pattern 0T
voice-class codec 1
dtmf-relay rtp-nte
no vad
sip-ua
credentials username 004930129854765 password 7 <password> realm sipgate.de
authentication username 004930129854765@sipgate.de password 7 <password>
no remote-party-id
retry invite 2
retry register 10
retry options 1
timers connect 100
registrar dns:sipgate.de expires 3600
sip-server dns:sipgate.de
host-registrar
telephony-service
no auto-reg-ephone
max-ephones 20
max-dn 40
ip source-address 192.168.5.99 port 2000
load 7960-7940 P00308010200
max-conferences 8 gain -6
web admin system name cisco secret 5 <password>
dn-webedit
time-webedit
transfer-system full-consult
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn  1  dual-line
number 1001 secondary 004930129854765 no-reg primary
**DEBUG INCOMING**
*Nov  2 23:05:09.759: //8/xxxxxxxxxxxx/CCAPI/cc_api_caps_ind:
   Call Entry Is Not Found
*Nov  2 23:05:09.763: //-1/F2512023800F/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=+4917661022799
   ----- ccCallInfo IE subfields -----
   cisco-ani=+4917975322866
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=004930129854765
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
*Nov  2 23:05:09.763: //-1/F2512023800F/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x49E2F7A4, Call Info(
   Calling Number=+4917975322866,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=004930129854765(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
  Incoming Dial-peer=11, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=8
   Guid=F2512023-04DD-11E1-800F-807480744F27, Outgoing Dial-peer=20001
*Nov  2 23:05:09.775: //8/F2512023800F/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=+4917975322866
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=1001
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
*Nov  2 23:05:09.779: //8/F2512023800F/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x4BAD9944, Interface Type=6, Destination=, Mode=0x0,
   Call Params(Calling Number=+4917975322866,(Calling Name=+4917975322866 )(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=1001(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=20001, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
The Call Setup Information is:
Call Control Block (CCB) : 0x4AB78130
State of The Call        : STATE_DEAD
TCP Sockets Used         : NO
Calling Number           : +4917975322866
Called Number            : 004930129854765
Source IP Address (Sig  ): 192.168.5.99
Destn SIP Req Addr:Port  : 217.10.79.9:5060
Destn SIP Resp Addr:Port : 217.10.79.9:5060
Destination Name         : 217.10.79.9
*Nov  2 23:05:14.575: //8/F2512023800F/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream             : 1
Negotiated Codec         : g711alaw
Negotiated Codec Bytes   : 160
Nego. Codec payload      : 8 (tx), 8 (rx)
Negotiated Dtmf-relay    : 6
Dtmf-relay Payload       : 101 (tx), 101 (rx)
Source IP Address (Media): 192.168.5.99
Source IP Port    (Media): 17066
Destn  IP Address (Media): 217.10.79.9
Destn  IP Port    (Media): 40144
Orig Destn IP Address:Port (Media): [ - ]:0
*Nov  2 23:05:14.575: //8/F2512023800F/SIP/Call/sipSPICallInfo:
Disconnect Cause (CC)    : 16
Disconnect Cause (SIP)   : 487
**DEBUG OUTGOING**
   Guid=A9C0A698-04DB-11E1-801B-F8B7FAD2A1EA, Outgoing Dial-peer=10
Nov  2 22:48:51.650: //12/A9C0A698801B/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=004930129854765
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=+4917975322866
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   cisco-redirectreason=0   fwd_final_type =0
Nov  2 22:48:51.650: //12/A9C0A698801B/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x4A07C064, Interface Type=3, Destination=, Mode=0x0,
   Call Params(Calling Number=004930129854765,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=+4917975322866(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE, Outgoing Dial-peer=10, Call Count On=FALSE,
Call Control Block (CCB) : 0x4ADCE9F0
TCP Sockets Used         : YES
Calling Number           : 004930129854765
Called Number            : +4917975322866
Destination Name         : sipgate.de
Nov  2 22:48:56.826: //13/A9C0A698801B/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
Negotiated Codec         : No Codec
Negotiated Codec Bytes   : 0
Nego. Codec payload      : 255 (tx), 255 (rx)
Negotiated Dtmf-relay    : 0
Dtmf-relay Payload       : 0 (tx), 0 (rx)
Source IP Port    (Media): 18588
Destn  IP Address (Media):  -
Destn  IP Port    (Media): 0
Nov  2 22:48:56.826: //13/A9C0A698801B/SIP/Call/sipSPICallInfo:
Disconnect Cause (CC)    : 38
Disconnect Cause (SIP)   : 503
1 ACCEPTED SOLUTION
Re: Outgoing Calls SIP Provider (CME)
Hm, the debug you provided before is showing a 503 disconnect cause.
Is your uploaded config still accurate (since it's from march '10)? Your latest debugs reveal a different ITSP (telefonica instead of sipgate).
Are you sure the provider is working with SIP over TCP? Is the CME able to do a DNS-lookup for the record in the dialpeer?
Test both with:
dial-peer 10
session transport udp
end
ping sipgate.de
C`mon Voice Gurus. :-)
Any advice please.
Whats going wrong here ?
Jason
Can you post a 'debug ccsip messages' of both calls as well?
Yes, of course. But if i dial out. No debug appear. Why? See attched the incoming debug
Test both with:
dial-peer 10
end
ping sipgate.de
No, i have sent you the incoming debug. The other debug with  the error 503 was for outgoing. And for "debug ccsip messages" i didn`t get any output if i try to dial out
yes, its the same. Where do you see March?
Sorry, i modified the config a little bit for the public.
See next answer .
Test both with:
dial-peer 10
end
You are the man. That was the issue. Now it works. . Great. THANKS,
ping sipgate.de
CME#ping sipgate.de
Sending 5, 100-byte ICMP Echos to 217.10.79.9, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 36/41/56 ms
CME#
I was referring to the debug of the outgoiing (failing) call. It show SIP 503 disconnect cause and CC (call control) cause 38. This indicates networking issue e.g. no DNS/ip routing.
You better should set the global transport option to UDP, since that's the default anyway and used by most of the ITSP:
voice service voip
sip
no transport tcp
In this case you should see errors in some kind of TCP-debug because you're trying to establish TCP-sessions with a non-responsive host.
ps the creation date of your profile (march '10) confused me with the post creation date.
2821
