Outgoing calls to PSTN/Mobiles problem
The voice gateway is configured for MGCP and runs on ISDN 30 links.All incoming calls are working fine but we are unable to call to mobile/pstn numbers.Internal calls are working fine.I have tried the debug q931 and see taht no mobile/pstn calls are landing on the gateway.Also when i do sh controller the e1 controller up but it shows a large number in unavail secs counter.
What could be the possible reasons for this problem.
Thanks in advance.
Hall of Fame Super Gold
Re: Outgoing calls to PSTN/Mobiles problem
for the "unavail sec" problem, have you configured network-clock select and priority for the internface ? Once you do this, do clear counters and check again.
Hope this helps, if so please rate post!
Bronze
Check if you have the command..
pri-group timeslots 1-31 service mgcp
You can also send following output to me..
Sh run
Sh controller t1
Thanks!
I have checked the controller config and the
is configured.Also the network clock select and priority is configured .
Another thing that i see when i do a debug isdn q931 is that the calls to mobiles and PSTN are not landing on the gateway.But i can see the incoming calls fine.
I did a reset of the controller counters and the error of "unavail secs" are now cleared and not increasing.But calls to mobiles and PSTN numbers still not working.I had to route the calls through another gateway in order to sort the problem but that is just a temporary fix.
Please guide further.
Gold
can u attach the output of debug isdn q931 for a call to Mobile and one to a Fixed phone (Working calls)
Bronze
If the call is not routing to the gateway than the issue might be with the configuration on the CallManager. Have you verified that this gateway is configured the same as the working gateway in CM (CSS, Partitions, device pool, etc)?
163
