Community Member
outgoing calls to pstn not working
We are having a ccm setup with 4.1(3) with mgcp gateway. We are not able to make the calls to PSTN. But incoming calls from PSTN is working. I am getting requested circuit/channel not available error message in the debug as mentioned below.
VG#debug isdn q931
debug isdn q931 is ON.
VG#
Apr 27 14:39:39.854: ISDN Se1/0:15 Q931: TX -> SETUP pd = 8 callref = 0x00AF
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Calling Party Number i = 0x0081, '1069'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '9940028908'
Apr 27 14:39:39.886: ISDN Se1/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x80AF
Cause i = 0x82AC - Requested circuit/channel not available
Display i = 'REQUESTED CHANNEL NOT AVAILABLE'
Checked all the troubleshooting logs. In all of them it was mentioned that it is a temporary problem.
Please let me know the solution if anybody has solved this problem.
Krishna.
1 ACCEPTED SOLUTION
Gold
Re: outgoing calls to pstn not working
Krishna,
Try to add this command in the ISDN Serial interface:
isdn bchan-number-order ascending
Try to use 'ascending' ot 'descending'.
Hope this helps,
Juan Luis
Gold
Krishna,
Hope this helps,
Juan Luis
Community Member
Hi Juan,
Thanks a lot. Its started working after entering the command isdn bchan-number-order command.
KRishna
Hall of Fame Super Gold
Good catch. I was obviously very confused about "international standards" :)
possibly "isdn negotiate-bchan" could help.
Starting from 1 (ascending) is OK, that is the international standard.
Another possibility is that the switch has not been provisioned correctly, is this a new circuit ?
Finally, you may want either indicate the main number as calling, or the extensions. How to do that, depends if you are using CME or CM, MGCP or H.323.
Community Member
it solved today my problem..
it solved today my problem.. Great post..
Thanks for this help.
827
