Community Member
outgoing CNAME on EURO PRI. CUCME.
Hello group,
We faced strange problem with CUCME. Simple setup , I even reproduced in my lab. CUCME wont send outbound CLID.
config and debug isdn q931 below. Any advises will be greatly appreciated.
ephone-dn 1 dual-line
number 4001 no-reg both
name Ph1 BR2
ephone 1
device-security-mode none
mac-address 0023.049A.8276
type 7941
button 1:1
dial-peer voice 330 pots
destination-pattern 9001T
port 0/0/0:15
description CLID=34+8digits , CNAME , strip9
preference 1
controller E1 0/0/0
channel-group 17 timeslots 17-27
pri-group timeslots 1-16
voice-port 0/0/0:15
translation-profile incoming INBOUND
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn incoming-voice voice
isdn supp-service name calling
isdn bchan-number-order ascending
isdn outgoing display-ie
no cdp enable
Oct 14 23:05:43.247: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x1, Calling num 44228224003
Oct 14 23:05:43.247: ISDN Se0/0/0:15 Q931: Sending SETUP callref = 0x008D callID = 0x800E switch = primary-net5 interface = User
Oct 14 23:05:43.247: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8 callref = 0x008D
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Progress Ind i = 0x8183 - Origination address is non-ISDN
BR2(config-if)#
Calling Party Number i = 0x0180, '44228224003'
Plan:ISDN, Type:Unknown
Called Party Number i = 0x81, '0012012012001'
Oct 14 23:05:43.275: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x808D
Oct 14 23:05:43.819: ISDN Se0/0/0:15 Q931: RX <- ALERTING pd = 8 callref = 0x808D
Progress Ind i = 0x8088 - In-band info or appropriate now available
BR2(config-if)#
Oct 14 23:05:47.787: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x008D
Cause i = 0x8090 - Normal call clearing
Oct 14 23:05:47.795: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x808D
Oct 14 23:05:47.795: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x008D
1 REPLY
Hall of Fame Super Gold
Re: outgoing CNAME on EURO PRI. CUCME.
You mean calling name, not clid.
Which exact IOS is this ?
165
