Community Member
Outgoing DID not coming
I have voice gateway where ISDN is terminated. Incoming DID is OK since i gave secondary command under each ephone-dn (like number 1234 secondary 7831234) but when i dial outside (to pstn), only main number of ISDN is being displayed.
Hall of Fame Super Silver
Please post "debug isdn q931", probably what is happening is telco is overwriting your number with the BTN number either because your number is not formatted properly or because that's the way the circuit was ordered. We can see what is happening from the debug. Identify what you are seeing and what you expect to see.
HTH,
Chris
Community Member
ok i will post in a short while. but there is no command to enable outgoing DId?
VIP Super Bronze
You will need to configure voice translation rules to map your internal extensions to your DDI range for your provider to display it. When you place a call to most PSTN providers and the calling number shows as internal number, they will replace it with the Mian number i n your DDI range. So you need to create xlation rules to change your internal DDI range to your block of DDIs
Please rate useful posts
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Community Member
Main number =1234700
DID Range =700 - 800
Exten number =700 to 800
what will be the translation rule?. Thanks
VIP Super Bronze
Your DID range cant be 700-800..
is it 1234700- 1234800
then configure
voice translation rule 1
rule 1 /^\7[0-9]/ / /1234\1/
rule 2 /^\8[0-9]/ / /1234\1/
voice translation-profile DDI
translate calling 1
then apply to to your outbound dial-peer
357
