Outgoing Fxo CME 7.0
I have a 2821 with 8 fxo ports and 8 phones. I want each phone have his own fxo for outgoing/incoming calls.
For incoming i used the PLAR command under voice-port, that's ok.
But for outgoing it uses one of the FXO,I tried the trunk command but in this case all calls are sent to FXO even internal one. One solution is to apply the trunk command on a secondary lines dedicated to out calls but this is not alright for the customer. Only one line by phone.
How can I make each primary line of the phone using his own FXO for outgoing ?
Thanks for your answer
1 REPLY
Re: Outgoing Fxo CME 7.0
119
