Community Member
outgoing number displayed, can I set it per extension?
Hi. Currently all of our outgoing calls show up at the recipients end as one particular phone number.
I'd like my handset to go out with a differnt number displaying on the recipients phone.
How do I do this? Can it be done by translation profiles? Here's what we're doing at the moment:
voice translation-rule 1
rule 1 /433599/ /201/
rule 2 /433585/ /201/
rule 3 /487153/ /201/
rule 4 /43358./ /201/
rule 5 /43359./ /201/
voice translation-rule 2
rule 1 // /90/
voice translation-profile 1
voice translation-profile ADDZERO
translate calling 2
voice translation-profile INCOMINGDDI
translate calling 2
translate called 1
I'd like my number (210) to display as 487153 on the recipients phone
Community Member
Re: outgoing number displayed, can I set it per extension?
you can also do this on the CCM through the Route lists an groups etc :) im sure though if everthing is left blank in your ccm in the route lists etc and that your provider is allowing you to send individual CLI then it should be fine.
Community Member
Forgot to mention im using CCME
make sure your Telco allows this, i've seen way too many cases in which the config was fine but the telco was overriding the calling party IE and sending always the main number or the 1st DID from the ones assigned
java
if this helps, please rate
java
www.cisco.com/go/pdi
Community Member
Good point. Luckily they do allow it, we had that functionality on our old BCM system.
Configure a translation profile for outgoing calls for the calling party, and assign to your outgoing DP:-
For example
voice translation-rule 3
rule 1 /210/ /487153/
voice translation-profile Outgoing-CLI
translate calling 3
dial-peer voice 1 pots
translation-profile outgoing Outgoing-CLI
destination-pattern 9T
port 0/2/0:15
Rgds
Allan.
Pls rate helpful posts...
Community Member
Hi Al,
Just tried this, still appears to show up as the root of the PRI number, not 487153
Here's what ive done:
rule 1 // /90/
translate calling 2
translate calling 2
translate called 1
destination-pattern 920......
port 0/0/0:15
forward-digits 6
prefix 20
no sip-register
dial-peer voice 2 pots
description **Answers All Incoming Calls**
incoming called-number .
direct-inward-dial
port 0/0/0:15
dial-peer voice 3 pots
description ** Outbound International Call **
preference 1
destination-pattern 900T
port 0/0/0:15
prefix 00
no sip-register
dial-peer voice 4 pots
description ** Outgoing national landline / mobiles **
preference 10
destination-pattern 90[1-8].........
port 0/0/0:15
forward-digits 11
no sip-register
dial-peer voice 5 pots
port 0/0/0:15
Do I need to do anything here:
voice-port 0/0/0:15
translation-profile incoming INCOMINGDDI
cptone GB
timeouts initial 5
timeouts interdigit 5
Community Member
contact telco ;)
You appear to have missed the translate calling 3 from within the translation profile. Try adding this, if you still have problems then the telco must be restricing cli and sending the main billing noumber.
Rgds
Al.
hi
i have addressed an issue has problem similer but not same as urs
have a look at the following link this discussion link will be helpful to u :
http://forums.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified Communications and Video&topic=IP Telephony&CommCmd=MB?cmd=pass_through&location=outline@^1@@.2cc18628/7#selected_message
good luck
if helpful Rate
173
