Outgoing numbers -DDI's
Hi. I've installed a 2801 CCME system for one of my customers.
They have a bunch of DDI numbers. That works great, until someone has a missed call from them. The person with the missed call returns the call, and the head office 'main' system number shows.
Im using voice translation rules:
voice translation-rule 1
rule 1 /433599/ /201/
rule 2 /433585/ /301/
rule 3 /487153/ /201/
rule 4 /43358./ /201/
rule 5 /43359./ /201/
voice translation-rule 2
rule 1 // /90/
voice translation-rule 3
rule 1 /210/ /487153/
So basically what im trying to achieve is that if I call a number from a particular DN, I want to 'leave' my associated DDI number on the handset ive called.
Any pointers?
1 REPLY
Re: Outgoing numbers -DDI's
try the following
rule 1 /^\(....\)/ /043359\1/
voice translation-profile p1
translate calling 1
dial-peer voice 1 pots
destination pattrent 0.T
translation-profile p1 outgoing
port [portnumber]
this is just example
this trnaslation add the PSTN number to the las four DID number you have
u need to make sur eu put the right number otherwise the telco if recieve the wrong one will send the main number only
good luck
if helpful Rate
114
