Outgoing translation rule not working on voip dial-peer
Hi, I'm having trouble with a voice translation rule  that strips the prefix 99 off the called number on an outbound voip dial-peer.
The configuration is pretty straightforward and the voice translation rule works.  It looks as if the dial-peer is ignoring the translation profile.  Below is the configuration, the rule test result and a debug ccsip output that shows that the original called number is not translated and the call fails.  I hope someone can help please.  Thanks in advance.
voice translation-rule 3333
rule 1 /^99/ //
voice translation-profile strip99
translate called 3333
dial-peer voice 1001 voip
description --- outbound to WAN
translation-profile outgoing strip99
destination-pattern 996......$
progress_ind setup enable 3
voice-class codec 1
session protocol sipv2
session target ipv4:10.0.1.1
dtmf-relay rtp-nte
no vad
voiprtr01#test voice translation-rule 3333 996148123
Matched with rule 1
Original number: 996148123      Translated number: 6148123
Original number type: none      Translated number type: none
Original number plan: none      Translated number plan: none
voiprtr01#debug ccsip calls
SIP Call statistics tracing is enabled
voiprtr01#csim start 996148123
csim: called number = 996148123, loop count = 1 ping count = 0
csim err csimDisconnected recvd DISC cid(553013)
Mar 24 19:40:08.477 UTC: //553013/FF285B8A831B/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x46073E70
State of The Call        : STATE_DEAD
TCP Sockets Used         : NO
Calling Number           :
Called Number            : 996148123
Source IP Address (Sig  ): 192.168.102.1
Destn SIP Req Addr:Port  : 10.0.1.1:5060
Destn SIP Resp Addr:Port : 10.0.1.1:5060
Destination Name         : 10.0.1.1
csim: loop = 1, failed = 1
csim: call attempted = 1, setup failed = 1, tone failed = 0
Mar 24 19:40:08.477 UTC: //553013/FF285B8A831B/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream             : 1
Negotiated Codec         : No Codec
Negotiated Codec Bytes   : 0
Negotiated Dtmf-relay    : 0
Dtmf-relay Payload       : 0
Source IP Address (Media): 192.168.102.1
Source IP Port    (Media): 18936
Destn  IP Address (Media): 0.0.0.0
Destn  IP Port    (Media): 0
Orig Destn IP Address:Port (Media): 0.0.0.0:0
Disconnect Cause (CC)    : 1
Disconnect Cause (SIP)   : 404
Everyone's tags (2)
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: Outgoing translation rule not working on voip dial-peer
csim does not obey translation-profile.
A real call will.
A real call will.
Thanks Paolo, you saved my day
Thanks for the nice rating and good luck!
2091
