outogoing call blocking cme 8.6
       good morning, I've a cme 8.6 and now I need to configure a call blocking from few extension  to external calls-
  this is the cme config
service password-encryption
hostname cme
boot-start-marker
boot-end-marker
enable secret
no aaa new-model
clock timezone it 1 0
clock summer-time it recurring last Sat Mar 2:00 last Sat Oct 3:00
network-clock-participate wic 1
network-clock-select 1 BRI0/1/0
network-clock-select 2 BRI0/1/1
dot11 syslog
ip source-route
ip dhcp excluded-address 10.128.130.200 10.128.130.201
ip cef
no ipv6 cef
stcapp register capability 0/2/0 modem-passthrough
stcapp ccm-group 1
stcapp
stcapp feature access-code
stcapp call-control mode feature
isdn switch-type basic-net3
trunk group ALL_BRI
voice call send-alert
voice rtp send-recv
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
supplementary-service ringback h225-info
redirect ip2ip
fax protocol pass-through g711ulaw
sip
  registrar server
  no update-callerid
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice register global
mode cme
source-address 10.128.130.200 port 5060
max-dn 15
max-pool 15
timezone 23
time-format 24
date-format D/M/Y
hold-alert
call-forward system redirecting-expanded
url directory
http://10.128.130.200/localdirectory
file text
create profile sync 0012040223221737
network-locale IT
user-locale IT
voice register dn  1
number 113
name 113 Cordless Materna
no-reg
label 113 Cordless Materna
mwi
voice register dn  2
number 115
name 115 Cordless Sala Maestre
no-reg
label 115 Cordless Sala Maestre
mwi
voice register dn  3
number 202
name 202 Cordless Sala Prof
no-reg
label 202 Cordless Sala Prof
mwi
voice register pool  1
id mac 0001.3E13.4F29
number 1 dn 1
username 113 password 113
codec g711ulaw
no vad
voice register pool  2
id mac 0001.3E13.0D3E
number 1 dn 2
username 115 password 115
codec g711ulaw
no vad
voice register pool  3
id mac 0001.3E13.0D21
number 1 dn 3
username 202 password 202
codec g711ulaw
no vad
voice translation-rule 3
rule 2 /^0/ /00/ type unknown unknown
rule 3 /^3/ /03/ type unknown unknown
voice translation-profile ENTRANTI
translate calling 3
voice-card 0
license udi pid CISCO2801 sn FCZ110910B6
username ucmadmin privilege xxxxxxxx
interface Loopback0
description $FW_INSIDE$
ip address 10.1.10.2 255.255.255.252
ip virtual-reassembly in
interface FastEthernet0/0
ip address 10.128.130.200 255.255.254.0
duplex auto
speed auto
interface Service-Engine0/1
ip unnumbered Loopback0
ip nat inside
service-module ip address 10.1.10.1 255.255.255.252
service-module ip default-gateway 10.1.10.2
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface BRI0/1/0
no ip address
isdn tei-negotiation first-call
isdn point-to-point-setup
isdn incoming-voice voice
isdn map address .* plan isdn type unknown
isdn send-alerting
isdn sending-complete
isdn static-tei 0
trunk-group ALL_BRI 64
interface BRI0/1/1
no ip address
isdn send-alerting
isdn static-tei 0
ip forward-protocol nd
ip http server
no ip http secure-server
ip http path flash:
ip route 0.0.0.0 0.0.0.0 10.128.130.1
ip route 10.1.10.1 255.255.255.255 Service-Engine0/1
tftp-server flash:admin_user.html
tftp-server flash:admin_user.js
tftp-server flash:CiscoLogo.gif
tftp-server flash:Delete.gif
tftp-server flash:dom.js
tftp-server flash:downarrow.gif
tftp-server flash:ephone_admin.html
tftp-server flash:logohome.gif
tftp-server flash:normal_user.html
tftp-server flash:Plus.gif
tftp-server flash:sxiconad.gif
tftp-server flash:Tab.gif
tftp-server flash:telephony_service.html
tftp-server flash:uparrow.gif
tftp-server flash:xml.template
tftp-server flash:xml-test.html
tftp-server flash:Analog1.raw
tftp-server flash:Analog2.raw
tftp-server flash:AreYouThere.raw
tftp-server flash:AreYouThereF.raw
tftp-server flash:Bass.raw
tftp-server flash:CallBack.raw
tftp-server flash:Chime.raw
tftp-server flash:Classic1.raw
tftp-server flash:Classic2.raw
tftp-server flash:ClockShop.raw
tftp-server flash:DistinctiveRingList.xml
tftp-server flash:Drums1.raw
tftp-server flash:Drums2.raw
tftp-server flash:FilmScore.raw
tftp-server flash:HarpSynth.raw
tftp-server flash:Jamaica.raw
tftp-server flash:KotoEffect.raw
tftp-server flash:MusicBox.raw
tftp-server flash:Piano1.raw
tftp-server flash:Piano2.raw
tftp-server flash:Pop.raw
tftp-server flash:Pulse1.raw
tftp-server flash:Ring1.raw
tftp-server flash:Ring2.raw
tftp-server flash:Ring3.raw
tftp-server flash:Ring4.raw
tftp-server flash:Ring5.raw
tftp-server flash:Ring6.raw
tftp-server flash:Ring7.raw
tftp-server flash:RingList.xml
tftp-server flash:Sax1.raw
tftp-server flash:Sax2.raw
tftp-server flash:Vibe.raw
tftp-server flash:music-on-hold.au
tftp-server flash:apps41.9-1-1TH1-16.sbn
tftp-server flash:cnu41.9-1-1TH1-16.sbn
tftp-server flash:cvm41sccp.9-1-1TH1-16.sbn
tftp-server flash:dsp41.9-1-1TH1-16.sbn
tftp-server flash:jar41sccp.9-1-1TH1-16.sbn
tftp-server flash:SCCP41.9-1-1SR1S.loads
tftp-server flash:term41.default.loads
tftp-server flash:term61.default.loads
tftp-server flash:apps45.9-1-1TH1-16.sbn
tftp-server flash:cnu45.9-1-1TH1-16.sbn
tftp-server flash:cvm45sccp.9-1-1TH1-16.sbn
tftp-server flash:dsp45.9-1-1TH1-16.sbn
tftp-server flash:jar45sccp.9-1-1TH1-16.sbn
tftp-server flash:SCCP45.9-1-1SR1S.loads
tftp-server flash:term45.default.loads
tftp-server flash:term65.default.loads
tftp-server flash:B016-1-0-4.SBN
tftp-server flash:7921-dictionary.xml alias Italian_Italy/7921-dictionary.xml
tftp-server flash:7921-font.dat alias Italian_Italy/7921-font.dat
tftp-server flash:7921-kate.utf-8.xml alias Italian_Italy/7921-kate.utf-8.xml
tftp-server flash:7921-kate.xml alias Italian_Italy/7921-kate.xml
tftp-server flash:be-sccp.jar alias Italian_Italy/be-sccp.jar
tftp-server flash:utf8_tags_file
tftp-server flash:rtl-sccp.jar alias Italian_Italy/rtl-sccp.jar
tftp-server flash:g3-tones.xml alias Italy/g3-tones.xml
tftp-server flash:gp-sccp.jar alias Italian_Italy/gp-sccp.jar
tftp-server flash:ipc-sccp.jar alias Italian_Italy/ipc-sccp.jar
tftp-server flash:mk-sccp.jar alias Italian_Italy/mk-sccp.jar
tftp-server flash:rp-sccp.jar alias Italian_Italy/rp-sccp.jar
tftp-server flash:tags_file
tftp-server flash:tc-sccp.jar alias Italian_Italy/tc-sccp.jar
tftp-server flash:td-sccp.jar alias Italian_Italy/td-sccp.jar
tftp-server flash:CME-locale-it_IT-Italian
tftp-server flash:CME-locale-it_IT-Italian-8.6.2.4.tar.cfg
tftp-server flash:g4-tones.xml alias Italy/g4-tones.xml
tftp-server flash:apps41.8-3-2-27.sbn
tftp-server flash:cnu41.8-3-2-27.sbn
tftp-server flash:cvm41sccp.8-3-2-27.sbn
tftp-server flash:dsp41.8-3-2-27.sbn
tftp-server flash:jar41sccp.8-3-2-27.sbn
tftp-server flash:SCCP41.8-3-3S.loads
tftp-server flash:APP6901SCCP.9-0-2-0.zz.sgn
tftp-server flash:KNL6901SCCP.9-0-2-0.zz
tftp-server flash:KNL6901SCCP.9-0-2-0.zz.sgn
tftp-server flash:SCCP6901.9-0-2-0.loads
control-plane
voice-port 0/1/0
translation-profile incoming ENTRANTI
compand-type a-law
cptone IT
bearer-cap Speech
voice-port 0/1/1
compand-type a-law
cptone IT
bearer-cap Speech
voice-port 0/2/0
compand-type a-law
cptone IT
connection plar 122
description FAX
station-id number 122
caller-id enable
voice-port 0/2/1
compand-type a-law
cptone IT
mgcp profile default
sccp local FastEthernet0/0
sccp ccm 10.128.130.200 identifier 1 version 3.1
sccp
sccp ccm group 1
associate ccm 1 priority 1
dial-peer voice 6 pots
description tcatch all dial peer for BRI/PRIv
incoming called-number .%
direct-inward-dial
dial-peer voice 50 pots
tone ringback alert-no-PI
destination-pattern 0T
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
direct-inward-dial
port 0/1/0
no sip-register
dial-peer voice 51 pots
direct-inward-dial
port 0/1/1
no sip-register
dial-peer voice 49 pots
destination-pattern 122
port 0/2/0
dial-peer voice 99 pots
description cordless Michele
destination-pattern 999
port 0/2/1
num-exp 222222 101
num-exp 222224 101
num-exp 222226 122
telephony-service
fxo hook-flash
max-ephones 30
max-dn 150
ip source-address 10.128.130.200 port 2000
auto assign 1 to 1 type bri
calling-number initiator
service phone videocapability 1
service phone webaccess 0
service phone ehookenable 1
service dnis overlay
service dnis dir-lookup
timeouts interdigit 5
timeouts busy 30
system message Scuole Regina Mundi Milano
user-locale IT
network-locale IT
load 7916-24 B016-1-0-4
load 7941 SCCP41.9-1-1SR1S
load 7945 SCCP45.9-1-1SR1S
load 7961 SCCP41.9-1-1SR1S
load 7965 SCCP45.9-1-1SR1S
load 6901 SCCP6901.9-0-2-0
time-zone 23
time-format 24
date-format dd-mm-yy
keepalive 120
max-conferences 4 gain -6
call-forward pattern .T
moh music-on-hold.au
multicast moh 239.10.16.16 port 2000
web admin system name admin password cisco
dn-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern .T
fac standard
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-template  17
softkeys remote-in-use  CBarge Newcall
softkeys idle  Redial Newcall Cfwdall Pickup Gpickup Dnd Login
softkeys seized  Cfwdall Endcall Redial Pickup Gpickup Callback
softkeys connected  Hold Endcall Trnsfer Confrn Acct Park
type 7941
ephone-dn  21  dual-line
number 201 no-reg primary
pickup-group 1
label 201 Sala Professori
description 201 Sala Professori
name 201 Sala Professori
huntstop channel
no huntstop
ephone-dn  23  dual-line
number 203 no-reg primary
pickup-group 1
label 203 Elena Redaelli
description 203 Elena Redaelli
name 203 Elena Redaelli
huntstop channel
no huntstop
ephone-dn  24  dual-line
number 204 no-reg primary
label 204 Massim Massagli
description 204 Massim Massagli
name 204 Massim Massagli
huntstop channel
no huntstop
ephone-dn  31
number 31 no-reg primary
label 301
description 301
name 301
no huntstop
ephone-dn  51  dual-line
number 501 no-reg primary
label 501 Nido
description 501 Nido
name 501 Nido
huntstop channel
no huntstop
ephone-dn  52  dual-line
number 502 no-reg primary
label 502 Cucina
description 502 Cucina
name 502 Cucina
huntstop channel
no huntstop
ephone-dn  53  dual-line
number 503 no-reg primary
label 503 Palestra
description 503 Palestra
name 503 Palestra
huntstop channel
no huntstop
ephone-dn  54  dual-line
number 504 no-reg primary
label 504 Sotto Auditorium
description 504 Sotto Auditorium
name 504 Sotto Auditorium
huntstop channel
no huntstop
ephone-dn  101  dual-line
number 101 no-reg primary
pickup-group 1
label 101 Centralino
description 101 Centralino
name 101 Centralino
huntstop channel
no huntstop
ephone-dn  102  dual-line
number 102 no-reg primary
pickup-group 1
label 102 Uff. Tecnico 1
description 102 Uff. Tecnico 1
name 102 Uff. Tecnico 1
huntstop channel
no huntstop
ephone-dn  103  dual-line
number 103 no-reg primary
pickup-group 1
label 103 Ufficio Acquisti
description 103 Ufficio Acquisti
name 103 Ufficio Acquisti
huntstop channel
no huntstop
ephone-dn  104  dual-line
number 104 no-reg primary
pickup-group 1
label 104 Marta Pochini
description 104 Marta Pochini
name 104 Marta Pochini
no huntstop
ephone-dn  105  dual-line
number 105 no-reg primary
pickup-group 1
label 105 Suor Letizia
description 105 Suor Letizia
name 105 Suor Letizia
huntstop channel
no huntstop
ephone-dn  106  dual-line
number 106 no-reg primary
pickup-group 1
label 106 Rosanna Giovinale
description 106 Rosanna Giovinale
name 106 Rosanna Giovinale
huntstop channel
no huntstop
ephone-dn  107  dual-line
number 107 no-reg primary
pickup-group 1
label 107 Patrizia Lezza
description 107 Segreteria 4
name 107 Patrizia Lezza
huntstop channel
no huntstop
ephone-dn  108  dual-line
number 108 no-reg primary
pickup-group 1
label 108 Paola
description 108 Paola
name 108 Paola
huntstop channel
no huntstop
ephone-dn  109  dual-line
number 109 no-reg primary
pickup-group 1
label 109 Mario
description 109 Mario
name 109 Mario
huntstop channel
no huntstop
ephone-dn  111  dual-line
number 111 no-reg primary
pickup-group 1
label 111 Gestore
description 111 Gestore
name 111 Gestore
huntstop channel
no huntstop
ephone-dn  112  dual-line
number 112 no-reg primary
pickup-group 1
label 112 Materna
description 112 Materna
name 112 Materna
huntstop channel
no huntstop
ephone-dn  114  dual-line
number 114 no-reg primary
pickup-group 1
label 114 Suore
description 114 Suore
name 114 Suore
huntstop channel
no huntstop
ephone-dn  116  dual-line
number 116 no-reg primary
pickup-group 1
label 116 Presid. primaria
description 116 Presid. primaria
name 116 Presid. primaria
huntstop channel
no huntstop
ephone-dn  122
number 122 no-reg primary
label FAX
description FAX
hold-alert 30 originator
ephone  1
description Suor Letizia
mac-address 001A.E22B.06E8
ephone-template 17
type 7941
button  1:105
ephone  2
description Centralino
mac-address 0022.905B.1EE9
ephone-template 17
blf-speed-dial 26 113 label "Cordless_Materna"
speed-dial 27 115 label "Cordless Sala Maestre"
speed-dial 28 202 label "Cordless Sala Professori"
type 7965 addon 1 7916-24
button  1:101 7m102 8m103 9m104
button  10m105 11m106 12m107 13m108
button  14m109 15m111 16m112 17m114
button  18m116 19m21 20m23 21m24
button  22m51 23m52 24m53 25m54
button  26m31
ephone  3
description Mario
mac-address 001A.E22A.8EDF
ephone-template 17
type 7941
button  1:109
ephone  4
description Gestore
mac-address 001A.E22A.F950
ephone-template 17
type 7941
button  1:111
ephone  5
description Patrizia Lezza
mac-address 001A.E22B.06F3
ephone-template 17
type 7941
button  1:107
ephone  6
description MartA Pochini
mac-address 001A.E22A.FA22
ephone-template 17
type 7941
button  1:104
ephone  7
description Ufficio Tecnico
mac-address 001A.E22A.FA43
ephone-template 17
type 7941
button  1:102
ephone  8
description Rosanna Giovinale
mac-address 0019.30C8.F90A
ephone-template 17
type 7941
button  1:106
ephone  9
description Ufficio Acquisti
mac-address 001D.A290.359A
ephone-template 17
type 7941
button  1:103
ephone  10
mac-address 0019.5659.6917
ephone-template 17
type 7941
button  1:107
ephone  11
description Materna
mac-address 001A.A1E7.87E4
ephone-template 17
type 7941
button  1:112
ephone  12
description suore
mac-address 001A.6CCB.477E
ephone-template 17
type 7941
button  1:114
ephone  13
description presidenza primaria
mac-address 001E.13AF.B641
ephone-template 17
type 7941
button  1:116
ephone  14
description 301
mac-address 0017.5A06.DCA3
ephone-template 17
type 7941
button  1:31
ephone  15
mac-address 0018.7334.D136
type 7941
ephone  16
description Elena Redaelli
mac-address 001A.6D2A.A851
ephone-template 17
type 7941
button  1:23
ephone  17
description Massimo Massagli
mac-address 0026.99EE.ABFE
ephone-template 17
type 7941
button  1:24
ephone  18
mac-address 001B.53B9.25AE
ephone-template 17
type 7941
button  1:21
ephone  19
mac-address 0018.B9E4.5BAC
ephone-template 17
type 7941
button  1:52
ephone  20
mac-address 9308.3BD1.E100
max-calls-per-button 2
type anl
button  1:122
ephone  21
mac-address 0026.CBBE.0B8F
ephone-template 17
type 7941
button  1:108
line con 0
line aux 0
line 130
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
line vty 0 4
password
login local
transport input all
line vty 5 15
password
login local
transport input all
scheduler allocate 20000 1000
ntp server 193.204.114.232
ntp server 193.204.114.233
end
hostname cme
boot-start-marker
boot-end-marker
enable secret
no aaa new-model
dot11 syslog
ip source-route
ip cef
no ipv6 cef
stcapp ccm-group 1
stcapp
trunk group ALL_BRI
voice rtp send-recv
voice service voip
redirect ip2ip
sip
  registrar server
  no update-callerid
voice class codec 1
mode cme
max-dn 15
max-pool 15
timezone 23
time-format 24
date-format D/M/Y
hold-alert
url directory http://10.128.130.200/localdirectory
file text
network-locale IT
user-locale IT
voice register dn  1
number 113
no-reg
mwi
voice register dn  2
number 115
no-reg
mwi
voice register dn  3
number 202
no-reg
mwi
number 1 dn 1
codec g711ulaw
no vad
number 1 dn 2
codec g711ulaw
no vad
number 1 dn 3
codec g711ulaw
no vad
translate calling 3
voice-card 0
interface Loopback0
duplex auto
speed auto
ip nat inside
no ip address
shutdown
duplex auto
speed auto
interface BRI0/1/0
no ip address
isdn send-alerting
isdn static-tei 0
interface BRI0/1/1
no ip address
isdn send-alerting
isdn static-tei 0
ip http server
ip http path flash:
control-plane
voice-port 0/1/0
compand-type a-law
cptone IT
bearer-cap Speech
voice-port 0/1/1
compand-type a-law
cptone IT
bearer-cap Speech
voice-port 0/2/0
compand-type a-law
cptone IT
connection plar 122
description FAX
caller-id enable
voice-port 0/2/1
compand-type a-law
cptone IT
sccp
sccp ccm group 1
direct-inward-dial
direct-inward-dial
port 0/1/0
no sip-register
direct-inward-dial
port 0/1/1
no sip-register
port 0/2/0
port 0/2/1
num-exp 222222 101
num-exp 222224 101
num-exp 222226 122
telephony-service
fxo hook-flash
max-ephones 30
max-dn 150
timeouts busy 30
user-locale IT
network-locale IT
time-zone 23
time-format 24
keepalive 120
dn-webedit
time-webedit
transfer-pattern .T
fac standard
ephone-template  17
type 7941
pickup-group 1
huntstop channel
no huntstop
pickup-group 1
huntstop channel
no huntstop
huntstop channel
no huntstop
ephone-dn  31
label 301
description 301
name 301
no huntstop
label 501 Nido
name 501 Nido
huntstop channel
no huntstop
label 502 Cucina
name 502 Cucina
huntstop channel
no huntstop
label 503 Palestra
name 503 Palestra
huntstop channel
no huntstop
huntstop channel
no huntstop
pickup-group 1
name 101 Centralino
huntstop channel
no huntstop
pickup-group 1
huntstop channel
no huntstop
pickup-group 1
huntstop channel
no huntstop
pickup-group 1
no huntstop
pickup-group 1
huntstop channel
no huntstop
pickup-group 1
huntstop channel
no huntstop
pickup-group 1
huntstop channel
no huntstop
pickup-group 1
label 108 Paola
name 108 Paola
huntstop channel
no huntstop
pickup-group 1
label 109 Mario
name 109 Mario
huntstop channel
no huntstop
pickup-group 1
label 111 Gestore
name 111 Gestore
huntstop channel
no huntstop
pickup-group 1
label 112 Materna
name 112 Materna
huntstop channel
no huntstop
pickup-group 1
label 114 Suore
name 114 Suore
huntstop channel
no huntstop
pickup-group 1
huntstop channel
no huntstop
ephone-dn  122
label FAX
description FAX
ephone  1
ephone-template 17
type 7941
button  1:105
ephone  2
ephone-template 17
button  26m31
ephone  3
description Mario
ephone-template 17
type 7941
button  1:109
ephone  4
description Gestore
ephone-template 17
type 7941
button  1:111
ephone  5
ephone-template 17
type 7941
button  1:107
ephone  6
ephone-template 17
type 7941
button  1:104
ephone  7
ephone-template 17
type 7941
button  1:102
ephone  8
ephone-template 17
type 7941
button  1:106
ephone  9
ephone-template 17
type 7941
button  1:103
ephone  10
ephone-template 17
type 7941
button  1:107
ephone  11
description Materna
ephone-template 17
type 7941
button  1:112
ephone  12
description suore
ephone-template 17
type 7941
button  1:114
ephone  13
ephone-template 17
type 7941
button  1:116
ephone  14
description 301
ephone-template 17
type 7941
button  1:31
ephone  15
type 7941
ephone  16
ephone-template 17
type 7941
button  1:23
ephone  17
ephone-template 17
type 7941
button  1:24
ephone  18
ephone-template 17
type 7941
button  1:21
ephone  19
ephone-template 17
type 7941
button  1:52
ephone  20
type anl
button  1:122
ephone  21
ephone-template 17
type 7941
button  1:108
line con 0
line aux 0
line 130
no exec
transport input all
line vty 0 4
password
login local
transport input all
line vty 5 15
password
login local
transport input all
end
1 REPLY
Hall of Fame Super Gold
There are many, many postsings about the same, please search before posting.
186
