Community Member
Outside caller accessing directory of extensions
We have a CCM5.1 and a Unity express.
When a outside caller attempts to look up a extension number by entering a users name- where does it pull that directory information from?
If the user has not recorded their name what do callers hear?
Andy
Community Member
Re: Outside caller accessing directory of extensions
This information would be pulled from CUE. If the user does have a recorded name then I believe they hear a generated recording of the entension.
Community Member
SO as long as the yellow uuser name fields are populated and the include in directory check box is checked they should be found by outside callers right?
Because I have 1 user who is not found yet appears to be configured correctly.
Andy
i'm not a CUE guru (still far from being =) ) but i believe the dial-by-name is the same as with unity, only users that have a recorded name will be listed in the directory when looking for them
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
134
