outside calls from OCS
We have call Manager 6.1 & OCS R2 .
Calls coming in to CUCM is fine, but calls made outside from the OCS is not happening. It gives the error with saying, not able to reach to gateway.
Checked with the SIP trunk on CUCM, tried reseting the trunk & route list. pattern used is 4 digit dialing
In DNA, on puttiing the calling party number & Dialled number, below is the output. It just ring for some time & thenit dial out for the user who is calling from OCS
  • Results Summary
    • Calling Party Information
      • Calling Party = 601790XXXX
      • Partition =
      • Device CSS =
      • Line CSS =
      • AAR Group Name =
      • AAR CSS =
    • Dialed Digits = 678362XXXX
    • Match Result = BlockThisPattern
    • Called Party Number =
    • Matched Pattern Information
      • Pattern =
      • Partition =
    • Pattern Type =
    • Time Zone =
    • Outside Dial Tone = NO
  • Call Flow
    • Note: Information Not Available
  • Alternate Matches
  • could you please suggest what could be the reason for not dialing?
    Regds,
    Navin Golani
    Re: outside calls from OCS
    FROM: <6783626602>;tag=d9be8f8b-c425-417a-b3cc-6e22833c7c95-60144943
    TO: <3164>;epid=92DA24DABB;tag=222cc8e63e
    CSEQ: 101 INVITE
    CALL-ID: 72203780-bab16bf4-20e40-c0b050a@10.5.11.12
    VIA: SIP/2.0/TCP 10.5.11.12:5060;branch=z9hG4bK58d61e98e4ca
    CONTENT-LENGTH: 0
    SERVER: RTCC/3.5.0.0 MediationServer
    |<:STANDALONECLUSTER><:STVPCM02><:3><:10.5.16.115><:><:STATE transition=""><:20000>
    03/25/2010 09:58:17.617 CCM|//SIP/SIPTcp(3,81,1)/wait_SdlReadRsp: SignalCounter = 183555|<:STANDALONECLUSTER><:STVPCM02><:3><:10.5.16.115><:><:DETAILED><:20000>
    03/25/2010 09:58:17.617 CCM|//SIP/Stack/Info/0x0/ccsip_spi_get_msg_type returned: 2 for event 1|<:STANDALONECLUSTER><:STVPCM02><:3><:10.5.16.115><:><:DETAILED><:40000>
    03/25/2010 09:58:17.617 CCM|//SIP/Stack/Transport/0x0/context=0xd8ffb68|<:STANDALONECLUSTER><:STVPCM02><:3><:10.5.16.115><:><:DETAILED><:40000>
    03/25/2010 09:58:17.617 CCM|//SIP/SIPTcp(3,81,1)/wait_SdlReadRsp: SdlRead bufferLen=351|<:STANDALONECLUSTER><:STVPCM02><:3><:10.5.16.115><:><:DETAILED><:20000>
    03/25/2010 09:58:17.617 CCM|//SIP/Stack/Transport/0x0/gConnTab=0xd8ffb68, addr=1930429706, port=5060, connid=37761, transport=TCP|<:STANDALONECLUSTER><:STVPCM02><:3><:10.5.16.115><:><:DETAILED><:40000>
    03/25/2010 09:58:17.617 CCM|//SIP/SIPTcp/wait_SdlReadRsp: Incoming SIP TCP message from 10.5.16.115 on port 5060 index 37761 with 351 bytes:
    SIP/2.0 200 OK
    TO: <3164>;epid=92DA24DABB;tag=82af28ee25
    CSEQ: 101 CANCEL
    CONTENT-LENGTH: 0
    03/25/2010 09:58:17.617 CCM|//SIP/Stack/Info/0x0/Checking Invite Dialog|<:STANDALONECLUSTER><:STVPCM02><:3><:10.5.16.115><:><:DETAILED><:40000>
    03/25/2010 09:58:17.617 CCM|//SIP/SIPTcp(3,81,1)/wait_SdlReadRsp: SignalCounter = 183556|<:STANDALONECLUSTER><:STVPCM02><:3><:10.5.16.115><:><:DETAILED><:20000>
    03/25/2010 09:58:17.617 CCM|//SIP/SIPHandler(3,84,1)/ccbId=0/scbId=0/sip_stop_timer: type=SIP_TIMER_DISCONNECT value=500 retries=10|<:STANDALONECLUSTER><:STVPCM02><:3><:10.5.16.115><:><:DETAILED><:20000>
    03/25/2010 09:58:17.617 CCM|//SIP/SIPHandler(3,84,1)/ccbId=0/scbId=0/sip_stop_timer: type=SIP_TIMER_EXPIRES value=180000 retries=0|<:STANDALONECLUSTER><:STVPCM02><:3><:10.5.16.115><:><:DETAILED><:20000>
    03/25/2010 09:58:17.617 CCM|//SIP/Stack/Transport/0xbe42d220/Sending ACK to the transport layer|<:STANDALONECLUSTER><:STVPCM02><:3><:10.5.16.115><:><:DETAILED><:40000>
    03/25/2010 09:58:17.617 CCM|//SIP/Stack/Transport/0xbe42d220/msg=0xba800018, addr=1930429706, port=5060, sentBy_port=0, is_req=1, transport=2, switch=0, callBack=0x9d75422|<:STANDALONECLUSTER><:STVPCM02><:3><:10.5.16.115><:><:DETAILED><:40000>
    03/25/2010 09:58:17.617 CCM|//SIP/Stack/Transport/0xbe42d220/Proceedable for sending msg immediately|<:STANDALONECLUSTER><:STVPCM02><:3><:10.5.16.115><:><:DETAILED><:40000>
    03/25/2010 09:58:17.617 CCM|//SIP/Stack/Transport/0xbe42d220/switch transport is 0|<:STANDALONECLUSTER><:STVPCM02><:3><:10.5.16.115><:><:DETAILED><:40000>
    03/25/2010 09:58:17.617 CCM|//SIP/Stack/Transport/0xbe42d220/Set to send the msg=0xba800018|<:STANDALONECLUSTER><:STVPCM02><:3><:10.5.16.115><:><:DETAILED><:40000>
    03/25/2010 09:58:17.617 CCM|//SIP/Stack/Transport/0x0/Posting send for msg=0xba800018, addr=1930429706, port=5060, connId=37761 for TCP|<:STANDALONECLUSTER><:STVPCM02><:3><:10.5.16.115><:><:DETAILED><:40000>
    03/25/2010 09:58:17.617 CCM|//SIP/Stack/Info/0xbe42d220/Sent Error Response since the Gw is Shutdown|<:STANDALONECLUSTER><:STVPCM02><:3><:10.5.16.115><:><:DETAILED><:40000>
    03/25/2010 09:58:17.617 CCM|//SIP/SIPTcp(3,81,1)/wait_SdlSPISignal: received a spi signal ...|<:STANDALONECLUSTER><:STVPCM02><:3><:10.5.16.115><:><:DETAILED><:20000>
    03/25/2010 09:58:17.617 CCM|//SIP/Stack/States/0xbe42d220/0xbe42d220 : State change from (STATE_DISCONNECTING, SUBSTATE_NONE)  to (STATE_DEAD, SUBSTATE_NONE)|<:STANDALONECLUSTER><:STVPCM02><:3><:10.5.16.115><:><:STATE transition=""><:40000>
    03/25/2010 09:58:17.617 CCM|//SIP/Stack/Info/0xbe42d220/Removing call id 22231|<:STANDALONECLUSTER><:STVPCM02><:3><:10.5.16.115><:><:DETAILED><:40000>
    03/25/2010 09:58:17.617 CCM|//SIP/Stack/Error/0x0/Bad holder type encountered : 1|<:STANDALONECLUSTER><:STVPCM02><:3><:><:><:ERROR><:40000>
    03/25/2010 09:58:17.617 CCM|//SIP/SIPTcp/wait_SdlSPISignal: Outgoing SIP TCP message to 10.5.16.115 on port 5060 index 37761
    ACK sip:3164@10.5.16.115:5060 SIP/2.0
    Date: Thu, 25 Mar 2010 13:58:12 GMT
    There is a problem in the mediation server. verified from the above logs
    591
