05-29-2013 08:59 PM - edited 03-16-2019 05:35 PM
hi,
i have CME and fxo ports, one line comming from service provider.
if call from outside it rings one phone (ext 2000) at reception, i want if one call from out side to ring two extension at same time (2000, 2002)
my config.
voice-port 0/0/0
connection plar opx 2000
telephony-service
max-ephones 35
max-dn 48
ip source-address 192.168.1.254 port 2000
auto assign 1 to 40
cnf-file location flash:
time-format 24
max-conferences 8 gain -6
transfer-system full-consult
secondary-dialtone 9
ephone-dn 1 dual-line
number 2000
ephone-dn 2 dual-line
number 2002
how can i do it ??
05-30-2013 12:43 AM
You can configure, for example, a shared line (search).
05-30-2013 11:35 PM
Hi, can anybody help
05-30-2013 11:44 PM
CME Single number reach is the solution for you.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmesnr.html#wp998638
Regards...
Ashok.
06-01-2013 08:40 PM
hi ashok,
can you plz help more i am new to this config, i have read the document its about IP phone and soft phone,
is this the correct config in my case:
ephone-template 1
softkeys idle Dnd Gpickup Pickup Mobility
softkeys connected Endcall Hold LiveRcd Mobility
ephone-dn 1
number 2000
mobility
snr 4085550133 delay 5 timeout 15 cfwd-noan 2001
snr calling-number local
ephone-template 1
ephone-dn 2
number 2001
mobility
ephone-template 1
06-01-2013 09:54 PM
Please look at:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmebasic.html
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
06-02-2013 04:45 PM
Hi Alkabeer,
The above looks fine. Your configuration makes SNR reach for both 2000 & 2001 numbers to reach to remote number starting with 408xxx which you configured. However, I have not seen binding the ephone-dn to a particular ephone which I assume you have already done
This is the relevant capture from same cisco doc which I shared with you which clears all of your doubts.
The following example shows extension 1001 is enabled for SNR on IP phone 21. After a call rings at this number for 5 seconds, the call also rings at the remote number 4085550133. The call continues ringing on both phones for 15 seconds. If the call is not answered after a total of 20 seconds, the call no longer rings and it is forwarded to the voice-mail number 2001.
ephone-template 1
ephone-dn 10
number 1001
mobility
ephone 21
mac-address 02EA.EAEA.0001
ephone-template 1
button 1:10
Regards...
Ashok.
Pls kindly rate if helpful or answered your question.
06-03-2013 08:51 PM
Hi Ashok,
thanks for yr help, just want to finally confirm the config.
Senario : i have analog line connected to one port of FXO wic, currently if anybody call from outside extension 2000 rings.
i have two receptionest on extensions 2000 and 2001, so i want anybody calling from out side to my number 40231456 two extensions rings at same time.
voice-port 0/0/0
connection plar opx 2000 " should i keep it ?"
telephony-service
max-ephones 35
max-dn 48
auto assign 1 to 40
time-format 24
ephone-template 1
number 2000
mobility
snr 40231456 delay 5 timeout 15 cfwd-noan 2001 "should i place the my correct number (40231456) ?"
number 2001
mobility
ephone 1 "Is this ephone correct ?"
mac-address 0011.2233.4455
ephone-template 1
button 1:1
ephone 2 "Is this ephone correct ?"
mac-address 0011.2233.5566
ephone-template 1
button 1:2
06-04-2013 04:54 AM
As above: you should use shared dn, or parallel voice hunt. Not SNR.
06-04-2013 05:47 AM
I am confused, do i need to configue SNR or shareddn or parallel voice hunt ???
does this config works
number 2000
ephone 1
button 1:1
ephone 2
button 1:1 "same button"
06-04-2013 05:50 AM
or can u se this ???
voice-port 0/0/0
voice hunt-group 1 parallel
pilot 2000
list 2000, 2001
final 2004
timeout 20
06-04-2013 08:23 AM
Shared line will give best results. Ephone-dn should be octo-line.
06-04-2013 09:40 AM
so the final config should look like
voice-port 0/0/0
ephone-dn 1 octo-line
number 2000
ephone 1
button 1:1
ephone 2
button 1:1
Is this correct ??
06-04-2013 09:46 AM
The best approach is to try configs yourself, to test and learn.
Thaht will also save you from asking repeatedly here.
06-04-2013 02:05 PM
I give +5 to Paulo's recommendation! That is the easiest and best solution
