Community Member
Outside Calls routed to voice ports
Hello i have a cisco voice gateway with two voice port used for cellular access. I have a E1. From inside i have a pattern to access that port and make the call to cellular. But now i want to be able to dial from home and access to that voice port to be able to make call to cellular through my voice gateway, ideas for this?
1 REPLY
Green
Re: Outside Calls routed to voice ports
If using CCM you can use Mobility Manager which is built in in 6.0
If simple Voice GW create a dial-peer incoming withouth direct-inward-dial and dial from there.
PSTN -- match incoming dial-peer
you will hear dialtone, then dial your number
Configure POTS dial-peer to hairpin the call
112
