04-11-2014 04:13 AM - edited 03-16-2019 10:26 PM
According to the DocWIki, there doesn't seem to be much difference between the CUCM 9 & CUCM 10 virtualisation requirements.
Is there any real difference between the CUCM 9 & CUCM 10 OVAs, or is it all just cosmetic?
GTG
04-11-2014 05:37 AM
Gordon,
I believe the change is that CUCM 10 uses RHEL6 vs. 5 and I am sure there are other smaller changes, you can always compare the files. I would deploy the correct one.
Chris
04-11-2014 05:46 AM
So what do I do if I build as CUCM 9, and then upgrade to CUCM10? Do I have to create a fresh VM and import the disc?
GTG
04-11-2014 07:02 AM
If you build it as 9 then you use OVA for 9, then after upgrade change the OS to RHEL6 and do whatever else is spelled out in the upgrade guide.
Chris
04-11-2014 07:40 AM
The vNIC also needs to be changed to vMXNET3, the RNs and upgrade guide mention this, the OVA 10.X README has all the instructions for the change.
04-11-2014 08:20 AM
Hi Gordon,
Hope all is well with you my friend!
I'll just add this reference to the good tips from our buddies Chris & Java (+5!!)
There is a nice discussion in this Ask the Expert with Amit & Raees in these 10.x notes;
https://supportforums.cisco.com/discussion/12103966/ask-expert-cisco-unified-communications-manager-cucm-version-100
Cheers!
Rob
