overhead paging giving continuous busy
we had a power outage last week, after that overhead bogen system is continuously giving a busy noise. Bogen is connected to an ATA, it has to be turned off due to conitnous busy sound. I have checked the 2811 config and it seems ok.
Hasrat
1 ACCEPTED SOLUTION
Silver
Re: overhead paging giving continuous busy
Hasrat,
One other observation - on your sh ephone ata it is showing an active call - was there really one up when this was taken?
Art
Silver
Hi Hasrat,
A number of possibilities and a few questions here -
The ATA or the Bogen  might have gotten fried by the power outage - try to put a normal analog phone on the port and go off-hook to see if you get dial-tone now.  If you get tone for awhile and then busy the ATA is likely fine but the Bogen appears to be  never going on-hook.  If you get busy from the start the ATA may be fried or need a reset.
Is the ATA registered to CCM?
What role does the 2811 have here?
Art
Hi Art,
This is a 2821 CME router and ATA is connected to HP procurve, here is the config & sh ephone ata related to paging:
ephone-dn  103
number 399
label PhoneOnly Paging
name PhoneOnly Paging
paging ip 239.0.1.20 port 2000
ephone-dn  105
number 400
label All Paging
name All Paging
paging ip 239.0.1.30 port 2000
paging group 103,133
ephone-dn  133
number 513
label Overhead Page 513
description Overhead Page
paging
CME#sh ephone ata
ephone-106[40] Mac:0023.5E1A.2390 TCP socket:[15] activeLine:1 REGISTERED in SCC                   P ver 1/1
mediaActive:0 offhook:1 ringing:0 reset:0 reset_sent:0 paging 0 debug:0 caps:7
IP:10.1.100.23 8039 ATA Phone  keepalive 16157 max_line 1
button 1: dn 40 number 410 CH1   SIEZE        CH2   IDLE         shared
paging-dn 133
Preferred Codec: g711ulaw
Active Call on DN 40 chan 1 :410 0.0.0.0 0 to 0.0.0.0 2000 via 10.1.100.42
G711Ulaw64k  160 bytes no vad
Tx Pkts 0 bytes 0 Rx Pkts 0 bytes 0 Lost 0
Jitter 0 Latency 0 callingDn -1 calledDn -1
ephone-107[41] Mac:235E.1A23.9001 TCP socket:[2] activeLine:0 REGISTERED in SCCP                    ver 1/1
mediaActive:0 offhook:0 ringing:0 reset:0 reset_sent:0 paging 0 debug:0 caps:3
IP:10.1.100.23 15699 ATA Phone  keepalive 16155 max_line 1
button 1: dn 42 number 413 CH1   IDLE         CH2   IDLE         shared
CME#
is ephone-106 showing offhook because bogen is unplugged ?
Hasrat
Silver
hi Hasrat,
If the Bogen is now unplugged from the ATA and the ATA is still showing off-hook the ATA has an issue - try power cycling it for starters - it should be on-hook in an idle state.  If you can't get it to go on-hookm it is very likely fried.
If it is still connected to the Bogen unplug the line - it should go to on-hook very shortly.
Like I said earlier - find an analog phone and plug it into the port - it will help determine whether the issue is the ATA or the Bogen.
Art
Silver
Hasrat,
Art
Hi Art,
I also noticed it after I sent the reply, the IP address was of a 7965, I restarted the ephone and now it does not show the call,
CME#sh ephone ata | b ephone-106
ephone-106[40] Mac:0023.5E1A.2390 TCP socket:[12] activeLine:0 REGISTERED in SCCP ver 1/1
mediaActive:0 offhook:0 ringing:0 reset:0 reset_sent:0 paging 0 debug:0 caps:7
IP:10.1.100.23 6660 ATA Phone  keepalive 12 max_line 1
button 1: dn 40 number 410 CH1   IDLE         CH2   IDLE         shared
paging-dn 133
Hasrat
Hello Art,
same site, now if you try to page I don't see ATA in offhook state, if I plug an analog phone it gets a dial tone and ATA goes offhook,
do you think ATA has gone bad ? there is no change in config.
thanks
hasrat
Silver
Hi Hasrat,
It sounds more like the Bogen has an issue.  If you connect the analog phone to the ATA and dial the paging number does the phone ring?  If so take it off-hook and see if you have voice cut-through.  If so the issue would very likely be the Bogen.  Has it been power cycled since the incident?
HTH,
Art
Hi Art,
Thank you for the reply, phone does not ring when connected to ATA and neither does it goes offhook, Bogen and ATA were recycled.
thanks
hasrat
Finally resolved, if I dilaed 399 the phones will get the page and by dialing 513 analog phone attached to ATA rang once and the IP phone showed connected , but if I connect Bogen it would ring once and if I speak nothing was heard, dialing 400 was giving fast busy. Deleted ephone-dn 105 which has the paging group configured and added it back, paging is working for phones and overhhead, any explanation will be appreciated ?
722
