Overlap sending
Hi guys, I want to submit you a little question related to the overlap sending in CUCM5
The question is simple: in my architecture there are some MGCP controlled voice gateways all with PRI E1 interfaces. One of these is the gateway for special international patterns. Customer requires that the calls directed to this PBX must be sent with digits in overlap and not all in one shot as usual.
I already tried to setup the Allow Overlap sending on the dedicated route pattern but what I'm seeing is that the calls continue to go to the international PBX in one shot generating an issue. Any suggestion?
Best Regards.
Marco Ziglioli
1 REPLY
Hall of Fame Super Gold
Re: Overlap sending
Check this thread:
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.2cbf1de7/9#selected_message
Apparently overlap sending w/ MGCP can be made to work, but I never tried myself.
225
