Community Member
Overlapping issue on h323 gateway
                  Hi there,  we have two h323 gateways confiugued with overlapping dial-pattern point to it.  one working, but another not, debug isdn show following.
CUCM version 8.6.2.21900-5.  Router CiSCO 2901 and IOS c2900-universalk9-mz.SPA.151-4.M4.bin.
Seem to me on the working router, the rest digits has been collected digit by digit, but on the not working one, the rest digits is not ignored.   Any comments are welcome. Roy
Debug from working router:
Aug 22 05:32:59.218: ISDN Se0/1/0:15 Q931: TX -> SETUP pd = 8  callref = 0x2D29
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA9839A
                Exclusive, Channel 26
        Calling Party Number i = 0x0081, '61298886290'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, '0011656778'   <<<<<<<<<<<<<<<<<<<<<<<<<
XXXX-VCGW#
Aug 22 05:32:59.278: ISDN Se0/1/0:15 Q931: RX <- SETUP_ACK pd = 8  callref = 0xAD29
Aug 22 05:32:59.518: ISDN Se0/1/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x1, Called num 2   <<<<<<<<<<<<<<<<<
Aug 22 05:32:59.518: ISDN Se0/1/0:15 Q931: TX -> INFORMATION pd = 8  callref = 0x2D29
        Called Party Number i = 0x81, '2'
                Plan:ISDN, Type:Unknown
Aug 22 05:32:59.862: ISDN Se0/1/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x1, Called num 3  <<<<<<<<<<<<<<<<<<
Debug form no working router:
Aug 22 2013 13:29:48.670 WST: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x2453
                Standard = CCITT
        Channel ID i = 0xA9838A
                Exclusive, Channel 10
XXXXX-vgw01#
Aug 22 2013 13:29:48.734 WST: ISDN Se0/0/0:15 Q931: RX <- SETUP_ACK pd = 8  callref = 0xA453
XXXXX-vgw01#
Aug 22 2013 13:29:53.086 WST: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x2453
        Cause i = 0x8090 - Normal call clearing
Aug 22 2013 13:29:54.082 WST: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8  callref = 0xA453
Aug 22 2013 13:29:54.082 WST: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x2453
some commands used in router related to the h323 overlap:
     voice service voip
     h323
          h245 signal overlap
     voice call disc-pi-off
     voice call send-alert
1 REPLY
VIP Red
Mate, we need a bit more info here, both debugs show the same calling and called number  I am not sure what and why you are using the overlap signal command.
shoot us the configs on both gateways and also Is the problem typical to certain dialed numbers or is it happening to all outbound calls?
Cheers
Please remember to rate useful posts, by clicking on the stars below.
145
