Overlapping Patterns - Internal Extensions/Outbound
Hello, All!
I've recently had many end users ask whether it would be possible to dial 10-digits for outbound calls. The environment currently requires a 9 for outside dialtone. I've thought about how to accomplish this, but my concern is that by creating a pattern such as "[2-8]XXXXXXXXX" any extensions not starting with 1 will be caught by this pattern. I’ve thought of two ways to combat the overlapping, modify the inter-digit timeout parameter, or hit # when finished dialing an extension. Both of those don’t quite satisfy me though as they affect the end-user.
Ultimately I'd like a solution that is invisible to the end-user, but so far I can't think of any that won't require some user retraining. Any thoughts and/or ideas are appreciated. Thanks for your time!
-Raymond
Everyone's tags (5)
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Your listed options are how you'd make it work, though I would advise strongly against it.  Overlapping dial plan is not a good idea in my opinion and relying on inter-digit timeout leads to bad user experience.
With that said if customer insists after understanding the implications then your solution will work.
HTH,
Chris
HTH,
Chris
Agreed completely. Thanks so much for your help.
My pleasure, please mark the question as answered if you have not further questions on this topic.
Chris
169
