Packet Drops from Priority Queue causing Choppy Voice
Hi all,
I am experiencing voice quality issue at one of my remote sites, when I talk to a user at this remote site I notice the call was cuting in and out but the user at the remote does not experience the issue (call quality is fine for user at remote site), so I am pretty confident the packet drops occur at the remote site and I can see packet drops from the priority queue in "show policy-map interface" command outputs. I've checked and double checked my QoS policy and I couldn't see anything wrong with it and I know bandwidth is not a concern, traffic load is pretty light.
anyone has any idea what would cause packet drops from the priority queue ? Could it be code related ?
I have a 3725 router running IOS version 12.3(14)T7 at this remote site with 4 bonded T1s. Below is the show "policy-map interface" outputs. You can see the total drops at the bottom.
sh policy-map interface atm0/ima0.1
ATM0/IMA0.1: VC 10/50 -
Service-policy output: voice_over_wan
Class-map: voice (match-any)
40631229 packets, 2925446180 bytes
5 minute offered rate 247000 bps, drop rate 0 bps
Match: ip dscp ef (46)
40572438 packets, 2921215020 bytes
5 minute rate 247000 bps
Match: protocol rtp audio
58785 packets, 4230440 bytes
5 minute rate 0 bps
Match: ip precedence 5
5 packets, 648 bytes
5 minute rate 0 bps
Match: access-group 100
0 packets, 0 bytes
5 minute rate 0 bps
Queueing
Strict Priority
Output Queue: Conversation 136
Bandwidth 65 (%)
Bandwidth 3900 (kbps) Burst 97500 (Bytes)
(pkts matched/bytes matched) 384830/27707760
(total drops/bytes drops) 28704/2066688
Thanks in advance !!!
Danny
  • IP Telephony
Green
Re: Packet Drops from Priority Queue causing Choppy Voice
Hi Danny,
I see match ip dscp ef ok,
can you clean statistics, and place some calls to see during that time packet drops increase?
can you check we r not re-writing rtp dscp value before?
Let us know
Hi Gonzalo,
The issue seems to only happens when there is a high call volume but I am confident that bandwidth is not a concern. Should I increase the Queue-limit size for the priority queue ?
Thank you !
Danny
206
