Paging Broadcasting message to mobile
I am new to paging implementation
Paging requires any additional software to integerate?
Paging can install in windows 2008 server?
How can i send brodcast message to mobile?
Re: Paging Broadcasting message to mobile
Yes, paging does require additional software ( could be any third party ). However, with cucm 9.x Cisco is offering Singlewire Informacast as well for paging. For all the details please check the following links
https://supportforums.cisco.com/thread/2190897
https://supportforums.cisco.com/docs/DOC-4194
Manish
Regarding broadcasting message to mobile it should be possible, Informacst does offer this solution
InformaCast Advanced Notification is a full-featured emergency notification solution that enables people to reach an unlimited number of phones, speakers,  cell phones, and other devices with text and live, ad hoc, pre-recorded,  or text-to-speech audio.
http://www.singlewire.com/informacast.html
Manish
Manish,
Why we need to subscribe Singlewire software,wihtout third party subscribtion paging will not work.
Singlewire is the only paging software that Cisco officially supports. You can use any third party paging software that runs on Windows or any other platform. However, important point to remember is that CUCM does not have inbuilt paging functionality, you will need some third party software.
Manish
Manish,
Thanks for your valuable information,
Once i done Paging integeration with CUCM,paging functionality will not work without third party software?
Without Singlewire Software or any third party Paging functionality will not work
Yes, as i said CUCM does not natively support paging. Its only with cucm version 9.1 that Cisco started shipping Informacast DVD and stuff with every new install. You are right, without Singlewire Informacast or any other third party software paging will not work with CUCM.
Manish
I need to also mention solution from 2Ring - PHONE SERVICES.
It delivers much more than just simple paging.
Try to find some time to get more information about it: http://www.2ring.com/NewJuice
Obviously, FREE or TRIAL license is available.
Martin
195
