Paging in CME
Is there any way to limit the time a call to a paging dn will remain connected? I have problems will users not hanging up or accidentally putting on hold. I need to be able to disconnect calls to the paging dn after a minute or so.
Re: Paging in CME
A timer can be configured on the voiceport:
voice-port 0/0/0
supervisory disconnect dualtone mid-call
timeouts call-disconnect 5
timeouts wait-release 5
Re: Paging in CME
Thanks for the reply. Unfortunately this will not help because it is straight voip. There is no voice-port involved.
Re: Paging in CME
How is the paging system connected to your call manager express? When you indecate straight voip is it that the paging system has a network connection that you use to access? "network would replace the e&m or fxo wic card" Im curious because I have to set up pageing for our stores and I havnt found a solution that allows me to have a pure network connection to an overhead paging amp. Any info is greatly appreciated.
Re: Paging in CME
We are using the paging feature of CME. Which means we have a full CUCM that connects H.323 to the CME. Then, when phones on the CUCM dial a RP that points to the CME we have phones setup that auto answer with the paging feature. Here is the config:
ephone-dn 1
number 816
name Paging 650
paging ip 239.0.1.20 port 2000
ephone-dn 2
number 815
name Paging 502
paging ip 239.0.1.21 port 2000
ephone-dn 3
number 812
name Paging 542
paging ip 239.0.1.22 port 2000
ephone-dn 4
number 817
name Page All
paging ip 239.0.1.23 port 2000
paging group 1,2,3
ephone-dn 5
number 8793
ephone 1
ephone 2
mac-address 0023.5EB7.12B2
paging-dn 2
ephone 3
mac-address 0023.5EB7.10F3
paging-dn 3
ephone 4
mac-address 0023.5EB7.1160
paging-dn 1
ephone 5
mac-address 0023.5EB6.D693
paging-dn 1
241
