11-28-2007 05:16 PM - edited 03-15-2019 07:28 AM
Hello everybody.
a customer needs paging on the callmanager 5.1. What do I need to implement the paging on the callmanager version 5.1(2b)?.
Does anybody has a link where I can find information about this feature to be implemented.
Walter Flores
11-28-2007 07:20 PM
True paging cannot be done in CUCM 5.1 without a 3rd party application. If you are only looking for 1 to 1 paging, you can create a separate CSS and partition; create separate lines on each device and have them auto answer with speakerphone.
11-29-2007 07:44 AM
Hi thank for answering.
Could you tell me which 3rd application can be used or where to find this information?
Walter Flores
11-29-2007 07:57 AM
there are two apps ive demoed
Berbee and Phonetop.
check them out
11-29-2007 08:41 AM
I have used the Berbee solution and the Cistera solution. I like them both.
11-29-2007 02:55 PM
Could you explain me, how these solutions works?
For instance once the IP Phone is added to service PAGING, they just dial a code and the programing IP phone groups will be heard live audio from The
First IP phone which add to the service?
Walter Flores
11-29-2007 06:40 PM
walter,
For the Berbee you use the phone services for the app. there are a good few options that you can allow or diallow, but basically, you press services, "paging" and he group and just page. you can have multiple goups or one big group accordingly. you can also send text as well as pre-recorded messages (text and/or audio) Note you must have multicast working properly for the audio.
the phonetop is simple and its just to install the application. phonetop also comes with a survey application that you can push to the phone. i personaly like this feature.
for my customers, its all according to the environment
Phonetop - cuistomers that require the paging and a bit more
Berbee - same as above but has IP speakers to reach persons in noisy environments
each of these solutions has demos that you can download and setup. i suggest you try both and see which one you might be comfortable with.
