Paging or Intercom Cisco CUCM 8.6
Hi, I´m new working with Cisco UCM and I would like to know how can I configure paging or intercom.
I would like to make calls to the speaker of all phones in my company, so if I press x number I will be speaking through the speaker of all company phones.
Can I do this with CUCM 8.6?
Thanks in advance.
Jaime Valencia
There's a difference between paging and intercom, intercom is 1:1, paging is 1:many.
Only the first is an out of the box feature
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/8_6_1/ccmfeat/fsgd-861-cm/fsintrcm.html
If you want paging, that's a separate server you need (informacast paging server), or a 3rd party paging system from some other vendor.
java
if this helps, please rate
Jaime Valencia
java
Thanks Jaime,
What I really like is paging considering your answer.
Since we are a company with more than 200 phones, I think we will need to go to a 3rd party paging system or pay for InformCast Advance.
Any recommendation for 3rd party paging system?
you can try the one from Aurus - http://aurus5.com/phoneup/paging
If you need to use 50 users in the group then you don't need license for Informacast solution .If you are looking for advanced features as well more than 50 users you need to have License for informacast .
http://www.cisco.com/c/en/us/support/docs/unified-communications/paging-server/117059-configure-informacast-00.html
Regards Akhilesh Nambiyath
