Community Member
Paging using FXO Ports
If the paging equipment can handle an FXO port is there any reason that we can not use the FXO port on the interface of a CUCME?
1 REPLY
Re: Paging using FXO Ports
Typically you would use FXS from CUCME to the paging system. However, i've seen valcoms use FXO and it should work...It all depends on the vendor requirements that you will be integrating with. So to answer your question yes.
262
