Community Member
Paging via an FXO Port
Hello! I have a Bogen Classic C-100 working in conjunction with a Wheellock into an FXO Port on my voice gateway that I'd like to use for paging.
I've confirmed with TAC that everything is configured correctly in CUCM. When I call my paging extension, I get a tone (which I assume is coming from the Wheellock as the Bogen does not send a tone), but I hear nothing I speak com out over the speakers. If I break the cable connection and dial the extension, I immediately get a busy signal.
In speaking with Bogen, they said that the port has to be configured for "600 ohms dry audio". Is anyone familiar with how the FXO port needs to be configured in order to do this?
Green
James,
On your fxo router/gateway
voice-port 0/1/0
description *** FXO TO BOGEN KIT ***
impedence 600r
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
Community Member
Thanks, Alex!
The gateway took the command with no errors but I am not seeing it on the port:
voice-port 0/3/1
no battery-reversal
description HQ Paging System
Is this normal? Forgive me as I don't have much experience with FXO.
Thanks for your help!
Re: Paging via an FXO Port
Hello
please ,do
# show voice port 0/3/1 .
Thank you
please rate all useful information
please find the below example
Router# show voice port 1/0/0
E&M Slot is 1, Sub-unit is 0, Port is 0
 Type of VoicePort is E&M
 Operation State is unknown
 Administrative State is unknown
 The Interface Down Failure Cause is 0
 Alias is NULL
 Noise Regeneration is disabled
 Non Linear Processing is disabled
 Music On Hold Threshold is Set to 0 dBm
 In Gain is Set to 0 dB
 Out Attenuation is Set to 0 dB
 Echo Cancellation is disabled
 Echo Cancel Coverage is set to 16ms
 Connection Mode is Normal
 Connection Number is not set
 Initial Time Out is set to 0 s
 Interdigit Time Out is set to 0 s
 Analog Info Follows:
 Region Tone is set for northamerica
 Currently processing none
 Maintenance Mode Set to None (not in mtc mode)
 Number of signaling protocol errors are 0
 Voice card specific Info Follows:
 Signal Type is wink-start
 Operation Type is 2-wire
 Impedance is set to 600r Ohm
 E&M Type is unknown
 Dial Type is dtmf
 In Seizure is inactive
 Out Seizure is inactive
 Digit Duration Timing is set to 0 ms
 InterDigit Duration Timing is set to 0 ms
 Pulse Rate Timing is set to 0 pulses/second
 InterDigit Pulse Duration Timing is set to 0 ms
 Clear Wait Duration Timing is set to 0 ms
 Wink Wait Duration Timing is set to 0 ms
 Wink Duration Timing is set to 0 ms
 Delay Start Timing is set to 0 ms
 Delay Duration Timing is set to 0 ms
Thank you
972
