03-31-2010 11:59 AM - edited 03-15-2019 10:03 PM
I have a valcom 2003 A unit, Valcom told me that this will work with a FXO port. Is my first time trying this could some one help me. I need to know if I need to configure the FXO port and how to connect to the Valcom etc..
Thanks all
Solved! Go to Solution.
03-31-2010 12:44 PM
OK, so sounds like you'll want to send a 1,2,3 etc. to the paging unit. Here's one way to do this.
1. Choose a prefix digit for paging, such as 8.
2. Configure a route pattern in CUCM that sends 8X to the FXO port
3. Depending on your gateway configuration (MGCP or H.323), you can either strip the 8 at the CUCM or at the gateway. With MGCP, you'll need to strip it using CUCM. For example, you could have a 8.X route pattern and configure a PreDot DDI on the route pattern. With H.323, you can send the digits to the gateway and strip the 8 at the dial peer.
The end result will be the users dial 80, 81, 82, etc depending on the zone that they want. CUCM will send only the last digit to the paging unit to tell it which zone to page to.
Hope this helps.
Brandon
03-31-2010 12:13 PM
CUCM or CME? Is the Valcolm expecting to receive digits?
Brandon
03-31-2010 12:17 PM
We have a CUCM 6.13, I'm a TDM guy moving to IP, in the old system we just press the page key then press the zone number 1,2,3 etc.
03-31-2010 12:44 PM
Hope this helps.
Brandon
