Passcode on Cisco IP Phone
Hello All
I would need an advise on the following;
I have a remote IP Phone and I am required to create a passcode for it to be able to make phone calls. The IP Phone is registering to a Router offshore setup as a Call Manager Express:
Is there any way I can configure the Call Manager Express Router to be able to allow only one phone registering to it to be setup with this passcode.
Any advice will be most welcome.
Many Thanks in advace.
Everyone's tags (5)
VIP Super Bronze
What version of CCME are you running..You can use FAC to achieve this
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Thanks for the reply
I am using the follwoing:
SCCP42.9-0-3S
VIP Super Bronze
Can you type show telephony-service on your gateway and send the output here. It will show which CCME version you are running
Router#     show telephony-service
CONFIG (Version=8.6)
Version 8.6
Max phoneload sccp version 17
Max dspfarm sccp version 18
Cisco Unified Communications Manager Express
For on-line documentation please see:
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/tsd_products_support_series_home.html
protocol mode default
ip source-address xxx.xxx.xxx.xxx port 2000
ip qos dscp:
ef (the MS 6 bits, 46, in ToS, 0xB8) for media
cs3 (the MS 6 bits, 24, in ToS, 0x60) for signal
af41 (the MS 6 bits, 34, in ToS, 0x88) for video
default (the MS 6 bits, 0, in ToS, 0x0) for serviceservice directed-pickup
no auto-reg-ephone
load 7906 SCCP11.8-2-2SR1S
load 7911 SCCP11.8-2-2SR1S
load 7942 SCCP42.9-0-3S
max-ephones 35
max-dn 10
max-conferences 4 gain -6
dspfarm units 0
dspfarm transcode sessions 0
conference software
privacy
no privacy-on-hold
hunt-group report delay 1 hours
hunt-group logout DND
max-redirect 10
cnf-file location: system:
cnf-file option: PER-PHONE-TYPE
network-locale[0] GB   (This is the default network locale for this box)
network-locale[1] US
network-locale[2] US
network-locale[3] US
network-locale[4] US
user-locale[0] US    (This is the default user locale for this box)
user-locale[1] US
user-locale[2] US
user-locale[3] US
user-locale[4] US
srst mode auto-provision is OFF
srst ephone template is 0
srst dn template is 0
srst dn line-mode single
time-format 24
date-format dd-mm-yy
timezone 0 Greenwich Standard Time
call-forward pattern .T
no transfer-pattern is configured, transfer is restricted to local SCCP phones only.
keepalive 30 auxiliary 30
timeout interdigit 5
timeout busy 10
timeout ringing 180
timeout transfer-recall 0
timeout ringin-callerid 8
timeout night-service-bell 12
caller-id name-only: enable
edit DN through Web:  enabled.
edit TIME through web:  enabled.
background save interval 10 minutes
Log (table parameters):
     max-size: 150
     retain-timer: 15
create cnf-files version-stamp 7960 Apr 13 2012 03:44:26
transfer-system full-consult
transfer-digit-collect new-call
local directory service: enabled.
Extension-assigner tag-type ephone-tag.
VIP Super Bronze
Right so you are running CCME 8.6
Below is the link to use to configure FAC..
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucme/admin/configuration/guide/cmefac.html
This is a link on this forum for similar configuration..
https://supportforums.cisco.com/message/3383747#3383747
Pls rate all helpfull posts
I put in the followng configuration on the CME router but did not obtain the results: any advice as to why this could be the case?
voice lpcor enable
voice lpcor custom
group 11 IPPhone
voice lpcor policy IPPhone
service fac
accept IPPhone fac
application
package auth
  param passwd-prompt flash:en_bacd_welcome.au
  param passwd 1463
ephone  8
lpcor type local
lpcor outgoing IPPhone
device-security-mode none
description BP Jordan
mac-address D4D7.4841.94C7
codec g729r8
type 7942
button  1:8
I will be grateful to have any advise on this.
Kaushik
VIP Super Bronze
Kaushik,
I provided a link with the full config required. I looked at your configuration and you dont have
1. AA config..
aaa new-model
aaa authentication login default local
aaa authentication login h323 local
aaa authorization exec h323 local
aaa authorization network h323 local
aaa session-id common
gw-accounting aaa
2.your lpcor configuration is wrong/incomplete
1. you need to configure lpcor for phone and PSTN destination you want to force authorization for
ex:
voice lpcor enable
voice lpcor custom
group 10 IPPhone
group 11 PSTN
service fac
accept IPPhone fac
accept PSTNT fac
voice lpcor policy PSTN
service fac
accept IPPhone fac
accept PSTNT fac
You configured the lpcor wrongly "lpcor outgoing IPPhone" it should be "lpcor incoming IPPhone"
3. You did not configure Paramaters correctly
application
package auth
  param passwd 5555
  param term-digit #
  param user-prompt flash:en_bacd_enter_dest.au
  param abort-digit *
  param max-digits 32
* PIN Configuration** (for the end user you want restricted)
username xxxxx password 0 yyyyy  (eg.username 5555 password 0 12345)
4. Apply the lpcor to your dial-peer for outgoing calls
dial-peer voice xxx pots
lpcor outgoing PSTN
5. apply lpcor policy to the phone
ephone  8
lpcor type local
523
