Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Passing Voice traffic in a PIX Firewall
Hi Guru's,
Can someone help to design a VOIP passing to PIX Firewall. My client is worrying if we will pass the traffic over the Firewall. Appreciate if someone could send me some guildlines or documentation to make the VOIP passes thru PIX smoothly. Do I need to know and consider the software version of IPCC and CM of my client?
Re: Passing Voice traffic in a PIX Firewall
Hi!
Yes, you need to consider the SW versions, the ports used can change between them.
Please refer to:
*** Cisco Unified Communications Manager 6.0 TCP and UDP Port Usage ***
www.cisco.com/en/US/docs/voice_ip_comm/cucm/port/6_0/60plrev1.pdf
The CUCM SRND has a chapter dedicated to Voice security, it can give you more information and it
includes examples too:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/6x/security.html
*** Cisco Unified Contact Center Express Port Utilization Guide, Release 7.0(1) ***
www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/crs/express_7_0/configuration/guide/uccx70prtuti.pdf
You can search on CCO for similar docs depending on the version you have.
Teresa.
Regards, Tere. If you find this post helpful, please rate! :)
Hi Teresa,
Thank you very much. I'll read all this thing over the weekend.
All suggestion are welcome.
Jong
119
