Password changes on CM, CER,UC
                   We are running CM version 8.5 and have CER and UC integrated on our network. One of our support personnel wants to change the passwords on the systems (why exactly I do not know) but myself and another technician are worried about issues that could pop up that we are not aware of. The passwords are currently all the same and if we changed them they would all still have the change passwords. What we are worried about are processes that we may not be aware of that have been configured somewhere with this same password for integration. Are they any concerns we need to be aware of if we do make these password changes on the boxes?   Thanks
1 REPLY
Hall of Fame Super Silver
Which passwords exactly are considered to be changed?
All CTI based applications such as CER, UCCX, etc use CTI Application user for the integration, so if any of those user passwords change they have to be retyped on the application as well. You will first need to determine which user is used for the integration and then either do not change those passwords or apply the change after the change is made.
HTH,
Chris
109
